Low Oil pressure after rebuild - NEED Your Wisdom!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RustyBolt, May 4, 2024.
  1. Big Road Skateboard
    6,190
    34,007
    May 2, 2021
    Oil cooler? Not a good sign if a reputable shop can't figure this out. There's only so many possibilities
    RustyBolt and Diesel Dave Thank this.
  3. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    Sounds like you have something sucked up in the oil pump and into the oil galleries.
    If you are loosing oil pressure past the pump and filter, you have a major blockage problem.
    Hate to tell you but your going have to take the block out and get it checked and cleaned out.
    Or your going loose you engine and all the parts and hard work you put into the engine.
  4. lester
    2,920
    7,889
    Jan 2, 2012
    NW, Iowa
    cat kit or aftermarket? cat shop?
  5. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Kind of my thought. Oil cooler was replaced about a year ago. And after seeing what one of those actually looks like inside, there's not a whole lot that can go wrong with them. Unless something of fair size gets in there and clogs it up. Of course, I didn't crack it open and really have a good look at the internals. So, maybe more to it than meets the eye.
    They swapped the oil pump after running in to this problem. As for that "major problem", starting to think they don't keep an eye on the shop rags.
    Aftermarket kit. IPD I believe. Unsure exactly where the head came from. I think IPD as well. Not a cat shop. But these folks are pretty well known for "knowing their stuff" on CAT engines. Although, I think they've mainly dealt with older, pre-Acert engines.
    I have read that there is one of the IVA bolts or a head bolt ( something about a bridge motor. 3rd one back is what I seem to remember) that needs to be shorter to allow oil passage. I mentioned that to them, and was told they knew that and already took care of it. I'll mention it to them again though.
    Thanks Fellas!!
    blairandgretchen Thanks this.
  6. Accidental Trucker
    Accidental Trucker Road Train Member
    3,358
    7,380
    Jun 4, 2015
    I had something like this after a S60 rebuilt. A shop rag got left and sucked into the oil supply, everything went to heck in seconds.
    aljihada and blairandgretchen Thank this.
  7. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    I feel for ya, I'm the same guy. I use the same independent mechanic I have for the last 10 years. He cuts counterbores for many other shops in a 200 mile radius, and I've watched him work over the years. He is surgeon general serious when doing an inframe or a transmission rebuild, takes it very seriously. His name is on the line. @wore out has used his services I believe.
    Thing I like about him is that he will back up his f-ups. If it left his shop and fails, anything from the tow, to repair, replacement, or re do. I'm certainly not his biggest customer, but I've stuck with him because of his integrity. He chose to eat $4k on injectors, because FL supplied the wrong ones, and his mechanic didn't check the numbers before installing, and FL wouldn't honor their mistake after 10 months. Maybe the reason he is down to just himself from a 5 man shop. But he did the right thing by me.
    I hope your shop will do the same.
    PDI I believe is the name for the aftermarket kit that you and @lester were referencing. McBee is another one that comes to mind.
    The camshaft was mentioned. If the lobes were inspected and not scored or damaged, there would be no reason to remove, but camshaft bearings would not be replaced either.
    When you said 'cracked liner' - why not just replace that cylinder pack? Was it up for an inframe?
    How many miles are on the engine - when was last rebuild?
    It'd be great to have 8-10 guys on here looking over the shoulder of your mechanic as he diagnoses and gets to the root of the problem, one of the reasons I like this forum.
    @sawmill hasn't weighed in, I think he's had some experience with this engine too.
    Anyway - you've mentioned a couple of times that the lack of cashflow is becoming a burden, hate to hear that. 7 weeks - is a long time to be unexpectedly down. Most shops could have this in and out the door within 2 weeks at most, even with parts availability issues.
    Good luck - again, just thoughts from another 'external parts changer' like yourself.
    RustyBolt and wore out Thank this.
  8. wore out
    wore out Numbered Classic
    15,960
    193,127
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    It’s gonna be a loose or not in place piston cooling nozzle. Anytime you have this kinda thing you gotta go back where you been. Good pressure prior to the filter says pump pickup and relief valve is ok. After the filter loosing it says it’s either filter it’s self or 1 helluva leak internal. Naturally first thing I would do is get the hell outta there before they #### up more #### playing the poke and hope game. Then I’d run it with the covers off. See what happens. Then I’d pull the pan, check piston cooling nozzles and all bearings. Make #### sure I didn’t have a .010 under crank with standard bearings. And I’d want to retorque it all myself. I’ve seen several swear oh my engine never been into when they are begging me to order their kit. Not to find out it’s turned .010 and CAT don’t even offer a #### insert for it.
    I know it sounds harsh, I’m not some holier than thou never made a mistake. I have and when I have we went through proper diagnosis to find it and fix it not poke and hope blame parts etc
  9. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    @RustyBolt - there you have it.
    RustyBolt Thanks this.
  10. RustyBolt
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    They said there was a mark of some sort on the cam that was minor and able to be polished out. Other than that it looked good.
    I have no history on the engine prior to purchasing it 6 years ago. It has been rebuilt at least once before though. As there were already shims cut in for the liners. It currently sets at just under 1.5 million. I decided to have the work done due to what I thought was going to be a cracked head and not being able to find any other cause for over-heating issues. I figured if they were in that deep, might as well do it all, right? I was just hoping to get another 5 or 6 years out of it before I parked it out back and used it for target practice.
    blairandgretchen and aljihada Thank this.
  11. RustyBolt
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Another symptom they have found that I forgot to mention. I'm unsure where they were seeing it, but somewhere they were seeing air bubbles, small like suds, in the oil.
    blairandgretchen and wore out Thank this.
