low pressure air alarm not working properly, ADVICE APPRECIATED
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TowHaul, Dec 17, 2017.
  1. TowHaul
    TowHaul Medium Load Member
    406
    77
    Mar 7, 2016
    Since i bought the truck several months ago the low air pressure alarm has not worked properly. (I never drove the truck commercially yet). The dash low air pressure symbol alarm goes off correctly with a barely audible alarm from the dash (NOT THE BUZZER). When pressure builds past the the low pressure cut off point the dash onl alarm symbol goes off and the dim chine. I at first thought maybe the buzzer itself was bad. But then i finally learned how this oddly built rear air bags DUMP VALVE works and unarmed/flipped the switch and as rear air bags dumped pressure, amazing the low air pressure BUZZER screamed alive, it was only until i turned the dump valve back off, the buzzer stopped. The buzzer will ONLY work if the dump valve is activated.
    To date i have changed out all of the air pressure switches in the dash and even swapped around the connectors. I am somewhat at a loss what to do next... wonder if there is a way to splice into the switch that alerts the dash alarm to go off, and tie that into the buzzer somehow... Oh i own a FL112 2002 freightliner.
    Cegrier Thanks this.
  3. TowHaul
    406
    77
    Mar 7, 2016
    any advice? again the buzzer goes off when the dump switch is activated but nothing when the toggle switch is off the air pressure falls
  4. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    Under the cup holders behind the glove box there are a bunch of air pressure switches. One could be leaking when you brake, or apply air. Check those.
  5. TowHaul
    406
    77
    Mar 7, 2016
    are there more air switches other than the large group behind the dash? I'm confused now. As stated above I replaced all the air switches behind the dash. (about 4 or 5 of them)
  6. Oldironfan
    5,777
    5,541
    May 22, 2017
    Maybe you airbags have a leak? Or your level sensor? If air is falling turn engine off and go listen by drive bags.
  7. TowHaul
    406
    77
    Mar 7, 2016
    i never said air is falling... air is holding just fine. THE BUZZER IS NOT GOING OFF. thats the irritating frustrating problem i am having. I can only get the low air alarm/buzzer to go off when i hit the dump valve. The dash low air alarm goes off correctly however.
  8. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Make sure the wiring is not spliced into, somebody might have ran something off a wire they should not have and then them computers control to much so check all that.
  9. frt60
    frt60 Medium Load Member
    312
    266
    May 22, 2014
    On the air switches thete are ev 2 types , 1 is open ,1 is closed make sure you didnt install wrong onr
  10. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    Wonder if sensor see's the loss of air from supply tank for air bags before the whole truck air system. Where's it located? Dual needle gage because getting reading from different air tanks.
  11. supersnackbar
    18,642
    44,922
    Aug 19, 2007
    Your Town, USA
    Not sure, but the buzzer going off when you dump your bags might be a reminder so you don't drive off without flipping the switch back. As far as a buzzer for low air pressure, unless you want one, you don't have to have one as long as there is a visible warning...DOT only requires one or the other to be present, they don't require both.
