Lube for fifth wheel SLIDE
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ichudov, Dec 9, 2018.
  1. ichudov
    ichudov Heavy Load Member
    742
    641
    Mar 14, 2012
    Berkeley, IL
    I often haul heavy loads that require me to slide the fifth wheel when I hook up my RGN. (forklift that weight 61,000 lbs).
    I have a Fontaine fifth wheel and slide.
    I use some lithium grease right now but I think that it gets pushed away or something. As a result the slide area is not properly lubricated and instead of sliding easily, it gets stuck, then suddenly unstuck and the truck shakes and I have to hit the brakes instantly to not slam anything, etc etc. I was wondering if there is any lube that stays put better?
  3. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,033
    Jul 12, 2017
    Are you talking about white lithium from a spray can? I think gear lube works good. Thick so it sticks. Plus the quart jug with the taper tip works for getting in the tight spots and applying.
  4. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Dish soap.
    It will wash away and not attract grime to plug things up. It won't last long but it won't make the problem worse. Dish soap is also good for washing windshields and cleaning the cab. Not a one trick pony. :)
  5. Banker
    Banker Road Train Member
    4,143
    12,196
    Aug 19, 2012
    This is the best lube I have found. It isn’t cheap but worth it to me.
  6. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Try chainsaw bar oil, seems to last for awhile.
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    This stuff works awesome! I use it on the top plate as well as the slider.
    18,750
    45,516
    Sep 18, 2006
    the road less travelled
    Lucas makes some for the top and slide as well, it comes in a non pressurized plastic bottle with a tip which can be left very small or opened more to suit, it doesn't pour well when cold, though, I used it when unhooking or for warm weather.
    The correct way to slide a plate is to dolly down and dump the suspension, taking the majority of the weight off and sliding is easy, then, else use a pry bar to position it carefully while unhooked from a trailer.
    I usually don't have to move it much or often l, so that works well for me.
    Bean Jr., x1Heavy and daf105paccar Thank this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    Bar Oil, Dish Soap, Bar Soap (Very temporarily, first rain removes it) Old time bearing grease in red form (This one has gotten VERY hard to find. I think there is still a dab here and there maybe, but something to do with process of making removed certain chemicals or substances which once made it very good.)
    25(2)+2 Thanks this.
  10. JReding
    JReding Road Train Member
    1,955
    3,504
    Sep 8, 2014
    Puyallup, WA
    8C6EED79-5F87-4984-9B0E-E1E4E1B2BB99.png When I can find the red grease in the spray can, I get that. I haven't been able to get it lately, so I've been using this, and it works pretty well for me, on the slides and the top plate.
    ichudov Thanks this.
  11. supersnackbar
    19,266
    47,955
    Aug 19, 2007
    Your Town, USA
    If all else fails
    gentleroger and Bakerman Thank this.
