Lubrication of tractor and trailer?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jaguar011, Jul 7, 2015.
  1. jaguar011
    jaguar011 Light Load Member
    90
    21
    Jan 28, 2015
    How often I need to lubricate tractor and trailer or how many miles?
    Thank you.
  3. scottied67
    scottied67 Road Train Member
    10,817
    12,619
    Mar 14, 2010
    california norte
    I do mine about every 3 weeks. Well let's say every 6 weeks it goes in for an oil change and full grease lube all around. Then 3 weeks later I get down and do it again.
    Every time I drop the trailer, before hooking back up, I grease the 5th wheel which is about once a week.
  4. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    I have always lubed and changed oil/filters at 15,000 miles using 15-40 non synthetic oil. I use mobil delvac. My 98 pete had 1,100,000 miles when I sold it,,original u-joints, front axle and tie rods were original too,never replaced any part that needed lubed
    scottied67 Thanks this.
  5. spyder7723
    spyder7723 Road Train Member
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    I try to do mine every weekend. In reality I end up missing a weekend a few times a year. Grease is 2.50 a tube. Takes less than thirty minutes and your u joints will thank you. Bonus is while under there you will see any seeping wheel seals before the dot does. It's a whole lot cheaper to find and fix any issues on your drive way than it is out on the road.
  6. AModelCat
    155,317
    I used to do most of the maintenance on my dad's trucks back when I was in highschool. The truck/trailer would get completely greased every weekend and the drive line, log bunks and s-cams were done again every Wednesday night because the bush roads tended to pound the grease out of those parts. Transmission throw out bearing and cross shafts got greased every 2nd week. Engine oil was changed at either 250 or 500 hours (depending on what was recommended) as logging trucks tend to generate more hours/less miles than a highway truck. He never had an issue with premature failures (I think he only every lost 3 or 4 trips due to breakdowns in his whole career as an o/o. Like spyder said, you'll catch things before the DOT will as well.
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    lube with oil change every 10,000 miles.
  8. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    15k Oil and lube, truck stays on decent interstate so I dont worry about it to much. Was thinkin of steping it up to every 7500 for a quick greese. Even if you dont do it ur self the TA charges 20$ and its done in minutes.
  9. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    We do oil changes every 15,000 as well with full lube, we also bring them in at 7500 for grease jobs and quick look over. Any time they're in the shop in-between, we'll hit the u-joints, clutch linkages and steering/suspension. My only battle with that is getting the guys to wipe off grease that pushes out.
    I HATE grease slung all over. When I grease, I wipe off the grease fitting, so dirt doesn't get pushed in. When I'm done I wipe off the fitting again and any grease that pushed out.
