Mack CL700 trailer air supply valve
Discussion in 'Mack Forum' started by MurphyT, Jan 13, 2020.
  1. MurphyT
    MurphyT Bobtail Member
    I'm having an issue with the red trailer air supply valve not staying engaged. I can hold it in and the trailer pressurized well. Once the trailer is pressurized then the yellow valve won't stay engaged either. Any ideas?
  3. Dave1837
    Dave1837 Road Train Member
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    How much air are you losing when the parking and trailer brake valves are pushed in?
  4. MurphyT
    We finally got the problem figured out. There were two hoses switched around on a valve mounted under the hood on the firewall and one of them was kinked. Frustrating problem but an easy fix.
