Mack T2130
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Jan 31, 2025.
  1. Dino soar
    Dino soar Road Train Member
    4,809
    26,922
    Dec 8, 2017
    I was wondering if anyone had any information on the Mack T2130 transmission.
    Just wondering if it's a good transmission shifts right all of that heavy duty like other macks?
    Also they say that if you take and change the shifter around, that transmission actually is an 18 speed.
    Is anyone familiar with this?
  3. Dave1837
    Dave1837 Road Train Member
    1,401
    4,346
    Nov 16, 2019
    Pennsylvania
    Not sure about the 18 speed part but my uncle worked as a mechanic for tri-valley waste, which was bought out by waste management, then worked for waste for 25 years. He said he's never found a broken tooth on a Mack trans out of the thousands he's had open.
    After seeing what kind of abuse the T310M's take at my part time construction job, I believe Mack makes the toughest trans on the market
    Dino soar Thanks this.
  4. Hammer166
    7,568
    27,574
    Aug 18, 2007
    ~8600+' and loving it!
    I had a 97 E7-454 with a 2130. No complaints, quiet and smooth, although not quite as quick shifting as an RTLO. IIRC, you also do not preselect the splitter on the Macks.
    Here's a post about 13 to 18: Mack 13 Speed to 18 Speed Conversion
  5. Dino soar
    4,809
    26,922
    Dec 8, 2017
    See that's what I like about that transmission.
    They changed this truck over to a Fuller and from what I understand there's some kind of work involved in doing that.
    I'd like to go to that 13 speed Mack.
    Not only if you buy a 13-speed you automatically get an 18-speed, but that thing has three counter shafts.
    That's Heavy Duty.
    People argue whether you can do the same with a Fuller 13 speed, but I don't think you can without damaging it.
  6. Hammer166
    7,568
    27,574
    Aug 18, 2007
    We dug into that on a thread on here once upon a time. If you go through the power paths, there's a spot in low range/ high split where there's a really high speed differential that never happens in a 13 speed. And in the 18 speeds there's a bearing there instead of the bushing that's in the 13. One of those deals where you probably never hurt anything unless you were using that under a high load.
    I've driven the old 13 speeds before they had interlocks on them, so you could shift the bottom side if you wanted. But most stuff was so short geared back then that there wasn't much point!
  7. Dino soar
    4,809
    26,922
    Dec 8, 2017
    I've been reading that they say in the Fuller transmission that there is a difference in that bushing between the 13 and the 18 and there may be something else.
    I think some of the 13s may have that bushing, I think the RTLO.
    But that Mack
    transmission is three countershafts. I know the case is aluminum, but it would probably weigh a thousand pounds if it were cast iron.
    That's got to be a heavy duty son of a gun
  8. AModelCat
    161,464
    I think the typical Eaton scales in at around 750-800 lbs.
