MBE 4000 Coolant Leak on back of block?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by sedyan, Nov 8, 2023.
  1. sedyan
    sedyan Bobtail Member
    Just looked today and I had a substantial coolant leak coming from backside of block where the transmission meets the engine block. It's not a head gasket because the head is about 5" above where the leak is. Can't see on the back of the engine so I cant try to describe it.
    On the passenger side between the starter housing and block, where they meet. There is a a slow stream of coolant coming from it.. I cant tell what to make of that. Any ideas?
  3. Judge
    89,673
    Coolant leaks were bad on the mbe4000
    check Those leaks.
    Or Coolant usually leaks on the coolant rail, it is a metal rail that connects all 6 cylinder heads together, it is all so called the Deareation line. They usually crack, or the crush washers leak.
