Mechanical N14
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by united972, Jun 1, 2021.
  1. united972
    united972 Light Load Member
    157
    22
    May 26, 2016
    I’m looking at a 1991 t600 with a n14 it has about 750k original miles very clean truck. I know the guy he was a family friend he used it on his farm.
    the question I have is how reliable are the 1991 n14’s and also it only has 350hp? Can I tune it more or will 350hp be enough doing over the road on I-80 with a dry van??
    I just don’t know much about the mechanical n14 as I do about the red top any help would be greatly appreciated.
    Also if you know a mechanic familiar the mechanical engine please send me his info.
    let me know don’t know much about the 1991 n14’s
    Coffey and mile marker 27 Thank this.
  3. mile marker 27
    mile marker 27 Road Train Member
    1,415
    1,738
    Dec 4, 2019
    Sounds like a good platform to build a very reliable, ease of maintenance engine. Air to air, with mechanical PT pump, sounds like you might get 500-550hp, with the right tuning.
  4. united972
    157
    22
    May 26, 2016
    Do you kno if the 350hp n14 is just the low end hp of that engine.
    mom just trying to figure out if I need to change internals also is the mechanical reliable
  5. blairandgretchen
    13,920
    76,478
    Dec 9, 2011
    South west Missouri
    I’d move on. Have a friend with a 1992 FLD with that motor. Wrong gears, farm truck, sunk 40k into it and sunk his business plan of OTR.
    I’ve driven it a few times, can’t be turned up without damage and it’s a boggy pig.
    Now the 2001 KW with an N-14, solid motor.
    united972, Coffey and DUNE-T Thank this.
  6. Dino soar
    Dino soar Road Train Member
    4,815
    27,068
    Dec 8, 2017
    Mechanical n14 is a great engine.
    I know they had a lower horsepower version that was made to be a lower horsepower but I think that was around 300.
    The 350 I wouldn't even worry about that I would just use it that's plenty for I-80. I'm sure you could get at least 400 safely if not more.
    If you really want an answer or go on to the Cummins 855 enthusiast Forum on Facebook someone there will be able to answer the question.
    Most likely it set up similar to a big cam. Probably just slightly higher compression Pistons the timing is quicker the injectors are smaller and the Turbo is probably similar if not the same.
    The gearing of the truck itself will have a lot more to do with the power really then that engine. That engine is 100%.
    Just to give you an example I have a big cam 350 horsepower that regularly goes through the Pennsylvania Pocono Mountains and I have no problem.
    If somehow you end up not interested in that truck let me know. Not really looking for another truck right now but a nice truck with that awesome N14 would be something good to have.
    You can p.m. me if you like.
    Coffey and spindrift Thank this.
  7. lester
    2,956
    8,077
    Jan 2, 2012
    NW, Iowa
    In a 91 wouldn't that be a big cam III? I know they are basically the same but... or am I wrong
  8. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    I ran the mechanical N14’s for several years in the CaseIH Steigers and they were from 350-400hp. Tractor engines are set up different than truck engines. Very solid engine, that I wouldn’t hesitate to have in a truck.
    Coffey Thanks this.
  9. Dino soar
    4,815
    27,068
    Dec 8, 2017
    No the series went Big cam 3 big cam 4 then NT88 and then mechanical n14.
    They were all similar but different, built on the same 855 platform.
    haycarter and Coffey Thank this.
  10. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    Weren’t the 444’s the NT88 series, with the STC pump and low flow cooling system?
  11. SmallPackage
    5,774
    18,532
    Dec 20, 2019
    Marion Texas
    Around the ‘89-‘90 time frame Cummins Southern Plains was testing some of the first N-14’s in a fleet of 24 GMC/White/Volvos and a couple FL’s run by a large Texas based grocery co. in San Antonio. They had just started getting away from big Ford cabovers a few years before this. These were truly mechanical because they had the old style small cam through bc 3 high flow aftercoolers on them. No manufacturer was interested in redesigning the front end of their trucks at that time for air to air except Paccar. Paccar was the manufacturer that really forced them to go towards air to air. Some of those engines ended up scattered around South Texas after the trucks were retired and sold at local auction. Most were local rock trucks for years afterwards.
    Coffey and AModelCat Thank this.
