Mercer sign on inspection
Discussion in 'Mercer' started by exhausted379, Apr 2, 2014.
  1. exhausted379
    1,978
    27,311
    Dec 1, 2013
    Just wondering how tough Mercer's sign on inspection is.
  3. bigred81
    bigred81 Medium Load Member
    648
    425
    Aug 5, 2013
    There is a good thread on starting out with Mercer, sounds like the inspection is pretty thorough.
  4. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    it is a thorough inspection, you can pass any scalehouse inspection after one.
    t bird Thanks this.
  5. exhausted379
    1,978
    27,311
    Dec 1, 2013
    Thank-you.
  6. exhausted379
    1,978
    27,311
    Dec 1, 2013
    Thank-you. I think everything is in order, but they can always find something wrong if they want to. I guess I was just curios if it was thorough or one of those nit picking inspections. Thanks again.
  7. skateboardman
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    some say its nit picking, they don't fool around. but its all legit items. don't think they are going to walk by and say its looks good, they go under it with a creeper
  8. ingedavi
    ingedavi Light Load Member
    53
    18
    Jan 1, 2008
    Eau Claire, WI
    Make sure your ABS is working correctly, that was a big problem with my orientation group. (If equipped)
  9. kona911
    kona911 Light Load Member
    241
    233
    Apr 8, 2007
    Redding, CA
    Same with my group. Something about the abs light must turn on and then off within 15 seconds on the trailer.
  10. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    They look for rust lines showing any loose bolts.
    They look hard for hoses rubbing each other or rubbing the frame rail.
    They check your dash abs light coming on and going out correctly. (And they don't take kindly to a switch on the light). Don't ask how I know that.
    They look hard but don't make up crap either.
    Also don't allow wigwag lights or sunvisors lower than 6 inches or is it 5 inches?
    Bigdubber and exhausted379 Thank this.
  11. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    I just went through it and it was a full inspection....But i must say it was professional and fair they found 1 item with the trailer the tape on the ICC bar was worn out and they handed me a piece of the tape for free.....on the truck the right front shock was blown and the left rear axle seal was leaking now i just put new breaks and drums on the truck before i left to sign on and the truck did sit for 6-9 months before i bought it when i did the breaks the seal wasn't leaking or i would of replaced it there were other trucks that had a longer list to do. my assessment it was a good proses and very fair and honest
    77fib77 Thanks this.
