Well...finally got the call I was looking for...got approved today an will be at orientation on the 6th of January.
Bad news: got up an ran a load over to Georgia from Alabama today an noticed my abs light wouldn't turn off on the trailer. (Brand new trailer btw)
Needless to say, being that we were hit with the holidays all of the trailer shops are booked for the next week an a half or so....so I may have to push my date up even further in order to get this trailer in the shop somewhere before I take it to mercer for inspection
Mercer update
Discussion in 'Mercer' started by jacquesi23, Dec 28, 2015.
Page 1 of 7
CasanovaCruiser Thanks this.
Since you are going up on a Wednesday, you will be hard pressed to get things done to roll out on Friday, so anytime you have a break at orientation, use that time to complete your tractor weigh ticket, your trailer measurement sheet. And the many other things you got to do, like headachecrack equipment etc. 8e else we will see you in Louisville on the 11th
Ditto with SBman.
I've had plenty of trailers that just took some fiddling with pigtails to get out of the yard.
Or being that it is brand new a coupler could have been "soft-set"
When I worked in manufacturing this was the biggest warranty claim.
A coupler is the plastic piece that connects wires together. If it's soft set everything will work fine until you hit a big enough bump that shakes it loose. Follow the wires and make sure all connections are actually secure, even if they appear to be good visually they could be separated.jacquesi23 Thanks this. -
I'll have to get weighed out an measured I'm sure. -
It depends on which axle the abs sensors are on.
Do they have a repair shop there as well?
I may end up having to let them repair the issue with the abs light on my trailer if I can't get it in a shop before Wednesday
Page 1 of 7
