Millercoors fort worth TX
Discussion in 'Shippers & Receivers - Good or Bad' started by 2hellandback, Jun 16, 2012.
  1. 2hellandback
    2hellandback Heavy Load Member
    978
    237
    Dec 19, 2007
    Blackfoot Idaho
    Exit guards are a holes ,,,,wont be hauling for them again. And if your over weight on any axles they wont adjust load to legal limits!!!!!
  3. Frank Drebin
    Frank Drebin Bobtail Member
    13
    Jun 4, 2012
    The West
    Then refuse the load. If you get a ticket its your fault.
  4. keepntruckin
    keepntruckin Light Load Member
    208
    98
    Dec 27, 2011
    Lexington,NC
    I'm not sure that you would have that option,, being that you don't scale until you've been loaded and have left the facility.
  5. Frank Drebin
    13
    Jun 4, 2012
    The West
    Yes you do.
  6. Tazz
    Tazz Road Train Member
    2,821
    1,133
    Oct 25, 2009
    Lynchburg,Tn
    You always have the option of taking load back. ALWAYS!
    Now you should consult your company before doing so.
    Must not have a scale there huh? Been awhile since I hauled any Coors but in Golden you were scaled in and out. Budweiser as well.
  7. mslashbar
    mslashbar Medium Load Member
    600
    804
    Jul 22, 2009
    elizabeth,co
    They have a scale there, weigh you in and out. They just won't tell you your weights. They won't let you leave if over gross, but could care less about your axle weights. They let you on the dock and will load it how you tell them if you want. Every time i loaded ther they were pretty good about loading it correctly.
  8. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    well budweiser weighs you each way and doesnt let you leave till you are legal
    once i had to sit 8 hours on a sunday while they did inventory before they fixed it
    in cartersville ny robotic forklifts weigh every pallet as they put it on and still screw it up
  9. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    My wife works for Miller Coors customer service. I told her about your complaint and she said she would forward your comments to the appropriate department which is their polite way of saying go kick rocks. :biggrin_25520:
    Arkansas Thanks this.
  10. db2681
    db2681 Heavy Load Member
    757
    420
    Jun 13, 2011
    Dayton,OH
    Never had that issue at the Ft. Worth Plant or any Miller, they won't tell you axle weights same reason Bud won't give you a print out of the scale readings, they don't want to be responsible if it was wrong. But they have reloaded me the one time I was heavy. As for the exit guards, i would be an a hole all day to if I had to deal with some of these drivers.
  11. Anonymousproxy
    Anonymousproxy Road Train Member
    2,108
    4,380
    Mar 2, 2015
    That's where I'm picking up now... So far they've done a good job of getting my temper fired up.
