Missed matched tires, Hi Pro next to a Low Pro on trailer?
Discussion in 'Ask An Owner Operator' started by albloomfield, Jan 7, 2019.
  1. albloomfield
    albloomfield Bobtail Member
    21
    20
    Oct 12, 2018
    Ok, here we go.
    I had a blow out on a trailer tire 12-28-18. I took it to a Petro. Told them I wanted the same sized tires that were on the trailer.
    I go home for a few days for New Years, get back on the road, outside tire to the one I replaced a week earlier blows out. Drove about 1,200 miles.
    Today I'm looking at the new tire that was replaced Friday and it has no tread on it. When I was a company driver for Knight I ran into this once, where they had a high profile tire next to a low profile and the tire wore about the same. So, I'm thinking they put the wrong tire on. I'm looking at it and outside tire is sticking up at least a half inch higher than the outside tire.
    I figure it out, Petro put on a 295/75 R 22.5, I've got 275/80 R 22.5 on the other tires. I call Petro and they tell me it's DOT legal to run these tires next to each other. He claimed they are the same tire. I talked to another trucker and was told 295 is high profile 275 is a low profile. Guy at Petro is claiming there's another problem, it's not that tire.
    I'm positive the reason the outside tire is wearing like that is because they don't match. I told him you can see they don't match, he claimed the difference is tread, I'm like no way tread would make a noticeable difference.
    Just wondering what your guys thoughts here. There's no Petro TA, WITHIN 200 miles of me right now, honestly don't think I can make it that far, so I'm taking it to loves.
  3. mslashbar
    mslashbar Medium Load Member
    601
    808
    Jul 22, 2009
    elizabeth,co
    If the tread depth was equal, there is only about 1/8" difference in height between these 2 sizes. If 1 was new and the other wore out there would be a lot bigger difference
    GYPSY65 and 6wheeler Thank this.
  4. albloomfield
    21
    20
    Oct 12, 2018
    The other tires have about 40,000 miles on them. It's a new trailer, that's the mileage I put on it since I got the trailer.
  5. albloomfield
    21
    20
    Oct 12, 2018
    The second tire was brand new. Inside and outside tire were both new Friday.
  6. Petty Cash
    Petty Cash Light Load Member
    106
    125
    Jan 12, 2013
    Pennsylvania
    They are pretty close to the same diameter. Fresh tread compared to worn tread can be a significant difference, and pairing them can cause one to chew up the other in a hurry.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    Wrong size tire. I've seen that happen within 600 miles .
    They put an 11R22.5 next to a low profile tire. It ate the low one.
    Dave_in_AZ and albloomfield Thank this.
  8. mslashbar
    601
    808
    Jul 22, 2009
    elizabeth,co
    295/75r22.5 is 39.9" tall
    275/80r22.5 is 39.8" tall
    11r22.5 is 41.4" tall
    These measurements are when new with the same tread depth.
    6wheeler and Petty Cash Thank this.
  9. albloomfield
    21
    20
    Oct 12, 2018
    I'm positive this is what happened, when I get to loves I'm going to see what they say, and get photos of everything. I'm thinking I'm going to have to put 2 new tires on. Guy at Petro said warranty probably won't cover it, but I can't get to a Petro, like 300. Miles to the nearest one.
    I specifically said I wanted same tire on, then asked why I wasn't informed, he said because it's the same tire. I would of never approved them putting a different sized tire on.
  10. mslashbar
    601
    808
    Jul 22, 2009
    elizabeth,co
    Different brands could vary a little bit due to different tread depths, that could be your problem.
    albloomfield Thanks this.
  11. albloomfield
    21
    20
    Oct 12, 2018
    What benefits me at all at putting on a different tire? At the very least shouldn't I be informed they are putting a different sized tire n, even if technically there isn't much difference?
    I wouldn't of let them put it on if I was told.
