Any drivers out there having any problems with swr or even the factory Antennas ,my new employer in Canada has told me I will be getting a cascadia and I've read so much negative post's about swr and other various problems ' so I take it would be a good idea to purchase a predator 10 k and perch for the drivers mirror... any drivers out there using the perch and the predator 10 k would appreciate your feedback ...
Modern tractor and factory fitted cb Antenna
Discussion in 'CB Radio Forum' started by stacks, Jun 14, 2014.
Page 1 of 5
I recently got moved into a cascadia. It came with those fm/satellite/cb antenna, that was mounted on the roof. My cb was throwing antenna problem light with the stock one. I bought a mount and the predator 10k and it got alittle better. I had to move the predator forward to get better swr. I think the stock antenna mess up my cb. Tomorrow I'm installing a new cb and testing it again
So you seem happy with the predator 10 k and the bird perch' did you have to do any additional grounding from the Antenna to the door hinge' and did you do the install yourself maybe you could post some pics if you get a chance .
I don't plan on changing anything either as long as I get another Cascadia. Rest of the system is a 24 y/o Uniden PC76, Fatboy Amp and an Astatic 636 Mic. Receives well, transmits clean. No bleed over, not loud and have had many compliments.stacks Thanks this. -
That's great you never had to do any additional grounding ' and the year of truck and other Electrical devices that could cause interference .
Additional devices in the truck were also a SiriusXM Radio (No issues) Rand McNally TND 720 GPS (No issues) MP3 player (No issues) Blue Parrot BT Headset (No issues) 19" Skyworth LCD/DVD HDTV (No issues)
One thing unique was the Fatboy amp. Wired up to the exact same pos/neg leads that powered my CB. No interference and no excessive power draw from the amp either whenever the radio was keyed up. -
You run quite a lot if devices there , I guess you had a good break because I know a driver who had an earlier cascadia he drove OTR and he tried so much to get his swr down extra grounding and bonding . Maybe freightliners newer models are radio friendly ....
I installed a new radio and my swr is staying at 2 now. It was around 1ish with my old one. I'll looked into it later. Btw my truck doesn't have antenna sticking out from the sleeper like this schneider. So I had to get a mount. If you get a condo maybe you can unscrew the factory antenna?rabbiporkchop and stacks Thank this. -
Instead of pinching the coax in the door you can run it behind the panel just below the A pillar and through the grommet in the firewall that is just above the clutch fluid reservoir. That is how I run mine and it works out very well.
Several threads here about the Cascadia antenna problem. One guy ran a new coax to the factory mount on the driver's side, replaced the antenna, and had good luck. I use the mirror mount bracket and a 5ft SkipShooter. As soon as I can get one, I will put a 7ft SkipShooter on the mount. It will still be just under 13'6". Longer is better when it comes to antennas.
Page 1 of 5
