fellow driver is attempting to mount a standard TV but having a hard time finding a TV that matches the mounting bracket for a flat screen ...
I measured the one in my Volvo and looks to be a 100x150 mm VESA mount but he is being told the standard VESA mount for small tvs is a 24x24mm pattern.
So, does he need to drill holes to make it work??? Seems odd that Volvo would give a mount for a flat screen but not use the standard holes needed or allow for a few different patterns by having multiple holes in the mounting bracket.
So, how does one mount a flat screen tv???
Thanks,
MD
Mounting a Flat Screen TV
Discussion in 'Volvo Forum' started by MidWest_MacDaddy, Sep 28, 2016.
In my Volvo the plate has 2 different holes to mount different size TV's. I put a 22 inch flat screen in and works great
KB3MMX and MidWest_MacDaddy Thank this. -
Cottonmouth85 Thanks this.
Sounds like he's missing the actual mounting bracket.
The mounting bracket that bolts to the TV is a separate piece.
You attach the TV to the bracket, secure the 4 straps to the bracket and put the loops over the corners of the TV and tighten them down.
Then you attach that bracket to the swing arm mounted in the cabinet.
VESA mounting holes are square regardless of TV size. I think you're measuring the swing arm bracket that mounts the TV bracket. -
That's it... must be missing that extra mounting equipment on the tv side. Thanks. I'll pass it along and now I know as well should I ever opt to bring in a bigger screen... for now, my iPhone and iPad are enough for me.
Again, thanks.beckdg Thanks this. -
There's always the redneck way--
MidWest_MacDaddy Thanks this. -
