Mpg difference between mid roof and Full condo?
Discussion in 'Ask An Owner Operator' started by 77fib77, Oct 17, 2016.
  1. 77fib77
    77fib77 Road Train Member
    10,190
    62,966
    Jul 7, 2010
    St Louis
    I dream of getting a bigger sleeper, I have a flattop. But I wonder what difference mpg is between a mid roof and a full height pulling a deck.
  3. Steel Tiger
    Steel Tiger Road Train Member
    2,665
    3,221
    Jun 6, 2012
    Orlando, FL
    Not sure of numbers, but 2 factors jump to mind right off the bat.
    1. Full condo is larger so there is gonna be more front surface hitting the wind, providing a greater resistance.
    2. Again, condo is larger therefore it will be heavier.
    Honestly, anything would be a step up from a flat roof.
    77fib77 Thanks this.
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Would also depend on what you primarily haul and the wheelbase of the tractor.
    blairandgretchen Thanks this.
  5. dlstruck
    dlstruck Medium Load Member
    481
    390
    Sep 8, 2016
    How often do you haul loads that are higher than a mid?
  6. bzinger
    bzinger Road Train Member
    16,604
    65,836
    Dec 10, 2014
    omaha , ne
    I have a mid roof fld classic and would really like a raised roof but in extreme heat raised roofs are very hard to cool .
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    You got that right!
    bzinger Thanks this.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I had a 2006 flat top Century that had a removable full fairing. I took it off for a few years pulling hopper then went back to dry van, but I couldn't put it back on right away as it was frozen to the ground. A few months after summer arrived I finally got around to putting it back on and saw an immediate 0.6 mpg improvement.
    So the difference between a condo and a mid roof would be something less than that. Maybe 0.3 or 0.4 mpg.
  9. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    It's almost .5 unless you are pulling high loads it will hurt your mpg
  10. Ridgeline
    22,144
    113,530
    Not much. A half a mile seems to be normal for it but driving habits and conditions dictate most of what changes you will see.
  11. blairandgretchen
    13,241
    70,631
    Dec 9, 2011
    South west Missouri
    Saw a friend with a flat top classic Pete go from a flat trailer to a conestoga - massive reduction in MPG.
    Following him through construction, he was literally blowing cones over with the amount of air he was pushing.
    insertnamehere, Orangees and 77fib77 Thank this.
