N14 cam timing?? How important and how to?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Green461, May 19, 2023.
  1. Green461
    Green461 Light Load Member
    154
    106
    Mar 22, 2019
    Southern WI
    A friend is swapping cams on an N14 and the gasket that came out of the cam followers were .027 I think, thats it, no shims. does one just put it back the way it was? Ive seen various vids and posts with the 2 dial indicators set up but no one explains what the hell they are doing and such. Anyone know of a PDF procedure on this somewhere?
    Engine was rebuilt before he got it so its hard to say if whoever did it, did it correctly then... So would like to verify so timing is perfect... be nice to read a procedure or see it from someone that knows how to communicate... these youtube vids are a joke.
    Thanks.
  3. OLDSKOOLERnWV
    18,866
    284,399
  4. xsetra
    xsetra Road Train Member
    5,160
    7,092
    Aug 21, 2011
  5. blairandgretchen
    13,610
    73,961
    Dec 9, 2011
    South west Missouri
    From my non mechanical experience, owning one - yes, the cam follower gaskets determine timing and are important.
    Oxbow and OLDSKOOLERnWV Thank this.
  6. OLDSKOOLERnWV
    18,866
    284,399
    Keep in mind, you need to reinstall the cam followers just as they came off the block. They can be a few thousands difference in them.
    Same cam key being used?
    Oxbow Thanks this.
  7. OLDSKOOLERnWV
    18,866
    284,399
    ^^^^^ Correct
    The majority of the timing is made with the cam key, then is fine tuned with the cam follower gaskets….
    blairandgretchen, Oxbow and xsetra Thank this.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,517
    6,576
    Aug 26, 2014
    It depends on if you have step time or electronic injectors.
    You surely have electronic injectors as you only have one gasket and it is a .027. The computer actually times when the injectors fire on those. I always just put them back the the way they were made with no problem.
    Step time engines are another subject.
    I found an N14 complete shop manual on line in a PDF. It was free.
    High Stepper, Oxbow and HoundDog7 Thank this.
  9. Green461
    154
    106
    Mar 22, 2019
    Southern WI
    Yes.
    Cam key? If the followers were correct to begin with.. This is what I want to... or help him verify. Was overhauled once in its life and unsure what was done or if it was 100% correct.
    It is a 1999. In a 1999 Kenworth T2000. From videos ive watched and things ive read most i see people using 2 gaskets, or at least one that is .047 or something and then add the thinner one.. Being just one super thin one is why I question and think he should verify it.
    OLDSKOOLERnWV and BoxCarKidd Thank this.
  10. BoxCarKidd
    4,517
    6,576
    Aug 26, 2014
    You never answered if electronic or not.
    Pittsburgh Power has a good You Tube on timing a N14 mechanical. The timing tool is on line for about $900.00.
    Quickserve is a great resource as xsetra said. Do that in your friends name. You only get a few free CPL look ups.
    I am sure there is a timing spec for jig timing an electronic engine but I never did that. There probably is. Just always put them back the way they were.
  11. OLDSKOOLERnWV
    18,866
    284,399
    Ok…. If he is pressing the cam gear off the old cam and reinstalling the on the new camshaft…. MAKE SURE THE KEY ALIGNING THE GEAR ON THE CAMSHAFT GOES BACK TURNED JUST AS IT WAS ON THE OLD CAMSHAFT….
    That key adjust the majority of the injector timing, the gaskets in the cam followers fine tune the adjustment….
    Oxbow and Big Road Skateboard Thank this.
