N14 cracked head or bad Injector Oring?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by thesvg, Apr 4, 2023.
  1. thesvg
    thesvg Light Load Member
    192
    13
    Dec 9, 2010
    Hello all. I bought a six pack back in September, one went bad last week, and the injector was warrantied. The reason it was removed, It was getting a 325 code for an open injector on a cummins n14.
    After a week with the replacement injector,, Truck started sputtering and eventually 325 code came back, along with a sputter (either compression or fuel pressure) and with fuel in the oil.
    https://youtube.com/shorts/xo52wWXKbHo?feature=share
    I will upload a video shortly. Thank you.
    Reason for edit: Added link for video
  3. Last Call
    Last Call Road Train Member
    7,568
    45,910
    Mar 15, 2021
    Those N-14 are famous for having the injector harness go bad also
  4. Big Road Skateboard
    6,721
    37,838
    May 2, 2021
    The code your getting is logged because of an electronic malfunction. I would be looking into the jumpers, then main harness.
    Could also turn in to ECM related. I've replaced more N14 ECM's than 60 series Detroits.
    And the sad fact, Cummins N14 reman injectors just don't last
  5. blairandgretchen
    13,659
    74,333
    Dec 9, 2011
    South west Missouri
    My limited knowledge guess would point toward harness replacement too.
    There's (RXand PX?) different grades of reman injectors too - I've known of some nightmare replacement stories on reman squirters.
    Last Call Thanks this.
  6. thesvg
    192
    13
    Dec 9, 2010
    I took everything apart today. The pigtail completely tore off. The retainer bolt came loose. It was cradled between a valve spring and a push tube. After dozens of injector swaps on these engines this is the first time it's ever happened to me. I'm still finding the cause of that bolt coming lose.
    While the push tubes and rocker arms and valve springs looked good. I dropped the retainer plate that holds the injector down the side of the block.
    I dont know whether to remove the cam follower or just drop the pan to fish out all the pieces.
    Truck was stopped a mile or who from incident. Still had good oil pressure, but was smoking badly.
    Needless to say. I feel very Grimm right now. My last N14 threw the No6 injector tube down the side of the block and left me a new window. This could have done the same or maybe it was starting to.
  7. IH9300SBA
    IH9300SBA Road Train Member
    2,371
    23,141
    Feb 26, 2021
    Retainer plate, you mean the injector hold-down? If so, it's too big to make it to the pan and is hung up on the cam followers. Good flashlight and a strong magnet will get it.
    thesvg, bjytech and Last Call Thank this.
  8. thesvg
    192
    13
    Dec 9, 2010
    My apologies, I meant to say the bracket that holds the injector spring together. The hold down stayed in place.
    I accidentally dropped it down bellow. I do have a good magnet, an endoscope that will be trying to fish it out as soon as the weather clears up.
    IH9300SBA Thanks this.
  9. mile marker 27
    mile marker 27 Road Train Member
    1,351
    1,707
    Dec 4, 2019
    Is the most common failure from the electrical or mechanical side, of the injector?
  10. Big Road Skateboard
    6,721
    37,838
    May 2, 2021
    Electrical in my experience
    mile marker 27 and IH9300SBA Thank this.
  11. mile marker 27
    1,351
    1,707
    Dec 4, 2019
    How hard is it to rebuild the mechanical side of the injector, then remove and replace the solenoid?
