N14 oil pressure when cranking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Feb 1, 2025.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,351
    1,707
    Dec 4, 2019
    I’ve got the new oil pump primed on this new in frame. Batteries though not new have been on charge overnight, with the ECM unplugged and both 10 amp fuses out. I cranked it for about 20 seconds at a time and oil pressure slowly went up to 10psi. Should it be higher when cranking? Should I go ahead at put fuses back in and plug up ECM and try it?
  3. blairandgretchen
    13,667
    74,380
    Dec 9, 2011
    South west Missouri
    It is a high volume, low pressure engine.
    Oxbow Thanks this.
  4. mile marker 27
    1,351
    1,707
    Dec 4, 2019
    Ok B&G, so is what I’m seeing ok?
    Oxbow and blairandgretchen Thank this.
  5. AModelCat
    161,670
    Have to remember that cranking speed is significantly lower than idle speed - I'd estimate at a bit more than 1/3. That means the oil pump is going to move significantly more oil once its idling.
    I'd start it up, its building oil pressure while cranking. Just watch your gauge and react accordingly if pressure is not building.
  6. blairandgretchen
    13,667
    74,380
    Dec 9, 2011
    South west Missouri
    Just what @AModelCat said -
    I’d fire it up and monitor oil pressure and shut it down if it doesn’t rise above 10psi.
    From memory you’ll be at 25-30 psi with hot oil, 35 plus with cold oil at idle.
    Have someone stand by and check for leaks too.
    bjytech, Oxbow and mile marker 27 Thank this.
  7. DUNE-T
    DUNE-T Road Train Member
    7,021
    17,080
    May 10, 2015
    Detroit, MI
    When I start the oil pressure sensor goes almost all the way up and then drops down to 20. After engine warms up it drops to 15. It would show 10 only when completely warmed up.
    Do u have an aftermarket or original oil sensor? Aftermarket show 5 psi less from my experience
    blairandgretchen Thanks this.
  8. mile marker 27
    1,351
    1,707
    Dec 4, 2019
    Original. Well, same one that’s been in it.
  9. blairandgretchen
    13,667
    74,380
    Dec 9, 2011
    South west Missouri
    ScanGauge Diesel
    I use one for my 1995, it at least reads the information to the ECM, bypassing the often incorrect older manual guages.
    mile marker 27 Thanks this.
  10. Big Road Skateboard
    6,723
    37,850
    May 2, 2021
    Fire it up. I've seen plenty of hot N14's idling at 9 psi. I can't recall for certain what Cummins spec was on a hot engine, but IIRC, 8 psi.
  11. mile marker 27
    1,351
    1,707
    Dec 4, 2019
    I’ve got the batteries continuing to charge and the Mrs. had made plans for me. I don’t have a radiator yet, so no charge air cooler hanging yet either. I’ll be back at it tomorrow. Oh, my other post about the oil supply tube not sealing at the pan,……. well I think I got that fixed. Loosened, the two on the bottom of pump and slightly loosened the two at the pan. A little persuasion with a rubber mallet and she’s, flush.
