Need some advice
Discussion in 'Ask An Owner Operator' started by Crazytrucker77, Sep 14, 2021.
  1. Crazytrucker77
    Crazytrucker77 Heavy Load Member
    848
    1,048
    Nov 23, 2014
    Grants Pass, OR
    I have a 99 Wilson curtainside trailer that I still owe about $4000 on and have put around 12 grand into it Replacing the curtain's, Valences, Air bags and other miscellaneous repairs. It needs new doors and new pillars in the back.. The estimate came up to about $6300 . Including the purchase price I'm into the trailer 22k already. The company I'm leased onto gives me an extra 10% for having a trailer so I can make any money I spend back by keeping the trailer. At this point I have made over the 22k by having the trailer. here is my conundrum. Do I continue putting money into this trailer or do I put that money towards buying a new trailer?
    feldsforever and D.Tibbitt Thank this.
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    How much is a new one?
    There’s really no right or wrong answer. If you don’t mind the maintenance on an older piece of equipment go that route. If you don’t mind making payments on a new one go that route.
  4. NYStarcar
    NYStarcar Light Load Member
    249
    595
    Oct 6, 2020
    In a van down by the river
    I guess it would depend on the shape of the rest of the trailer. If the air tanks and lines, wiring, brakes and tires are in decent shape it would be worth fixing.
  5. bad-luck
    bad-luck Road Train Member
    3,318
    6,100
    Nov 16, 2013
    Baltimore, Maryland
    If the trailer is structurally sound, I would keep it. After all the repairs are done you will be good for a while.
  6. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Unless you're buying a brand new trailer, you're just going to be starting all over again with same repairs eventually. At least with your current trailer you know what's been done, what it's going to need and who did the work. Another used piece of equipment and it's all another history mystery.
    feldsforever Thanks this.
  7. Lunatic Fringe
    Lunatic Fringe Medium Load Member
    477
    1,401
    Oct 1, 2016
    Keep what you've got. Trailers are in short supply at the moment. Even if you can find one you'll pay dearly for it. Wabash has an 18 month waiting list for new trailers.
    Solo Soul Thanks this.
  8. Crazytrucker77
    848
    1,048
    Nov 23, 2014
    Grants Pass, OR
    Around 75k
  9. Crazytrucker77
    848
    1,048
    Nov 23, 2014
    Grants Pass, OR
    For as old as the trailer is it's in decent condition structurally. Typical rust but not To the point where it is affecting the structure of the trailer. The electrical is in pretty good Condition because I upgraded all the lights to LED.Is the worst part of the trailer is the aluminum floor in the middle between the frame rails. There are a couple holes that I had to cover with steel plate and from what I have heard from some manufacturers they do not make this type of decking I have in my trailer anymore so I can't replace it. That is the main reason why I am having a hard time justifying putting more is putting more money into this trailer.
  10. NYStarcar
    249
    595
    Oct 6, 2020
    I guess it would be worth while to look at truck paper and see what some of the newer used units are going for.
  11. Ridgeline
    22,456
    117,642
    Keep it. Put the money into it, take care of it and let it make money for you.
    feldsforever and JoeyJunk Thank this.
