Never seen this before, loose lug nuts on steer tire? (pics)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 85COE, May 27, 2022.
  1. 85COE
    85COE Light Load Member
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    Should I be concerned? Driver steer only
  3. JDHIGGINS44
    JDHIGGINS44 Light Load Member
    113
    272
    Jun 29, 2015
    Waynesburg, PA
    Typically a tell tale sign those lugnuts are loose. I would check them ASAP.
  4. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Agreed. There seems to be an awful lot of rust on the studs and nuts. Clean everything up and retorque.
  5. AModelCat
    161,681
    Agree with the above. Telltale sign that the wheel nuts are loose.
  6. Sixela918
    Sixela918 Light Load Member
    257
    397
    Nov 24, 2021
    Phoenix, AZ
    Rusty trails? Hmmmm.... New country musician? No, I'm pretty sure that was name of some porn stud. Oh wait, I remember, rusty trails is the dead giveaway that lug nuts are loose. At least according to the pretrip routine/script we learned in school.
  7. supersnackbar
    19,832
    51,042
    Aug 19, 2007
    Your Town, USA
    And it's a big 'look at me' sign when you go by a cop or the DOT at the scales
  8. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    Thank you for the heads up. In the 15 years I have been driving I have never seen that before. I had checked them and they were all finger tight, but I made it back to the shop which was about 9 Mi away from my drop, and they went ahead and checked all of them, and said that there were four loose on the passenger side.
  9. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    It wasn't rust, when I wiped it off it was kind of like soot that you would find on an exhaust leak. Black powder type substance
  10. A5¢
    389
    544
    Oct 30, 2017
    After you get them all cleaned up, don't go gonzo with oiling them. Too much, and the streaks will turn black from the oil slinging off.
  11. Arctic_fox
    4,379
    23,915
    Sep 16, 2016
    Ive seen it a few times. Usually its a lug thats loose or oxidized. I typically just have the lugs replaced as a precaution then clean everything up with coke then brake cleaner.
