New driver CDL test...
Discussion in 'Questions From New Drivers' started by jakemcclure, Oct 31, 2011.
  1. jakemcclure
    jakemcclure Bobtail Member
    34
    4
    Sep 23, 2011
    JAMESTOWN,ky
    I am a truck mechanic and I can not stand it any longer not being able to "road test" the trucks i work on. I want to get my CDL's but i'm not sure how to go about it... i can drive a truck pretty good as far as bob tailing and backing trailers into spots. But I need a class a cdl because my buddy owns a wrecker and I want to be able to tow trucks also. can you take your CDL's in a wrecker truck? or would i have to have a tractor/trailer to get the combination vehicle (class a) ?
    thanks for the advice,
    jake
  3. Cudascious
    Cudascious Medium Load Member
    350
    148
    Feb 25, 2011
    New Mexico
    you need a tractor and a 53' trailer to get a combination endorsement, maybe a 48'er. A wrecker truck would probably only be good for a CDL-B, I would think you could bobtail legally with a class B. Not sure though.
  4. Scorcher21
    Scorcher21 Light Load Member
    146
    141
    Apr 20, 2011
    Crossville Tn
    its cake dude. sounds like you already know the hard part. learn the pre trip, drill it into your head, know the names of every component, not just to know em but because by knowing em you know what your looking for in the way of defects., know the air brake tests, and every component of your baking system. If something should fail you should know by sight sound and feel what happened and how to control it. know the smith system by heart and practice it everyday, no matter what you drive. Know about load placement and securing. know about centrifugal force and how it effects loads. Know about brake lag and fade. learn what to do when an 80,000lb projectile becomes unruly and you have to choose between one of two horrible options. have a good head on yor shoulders and practice common sense and you will have no problem at all
  5. 7122894003481
    7122894003481 Bobtail Member
    1,996
    Sep 6, 2011
    I read on here that you can take the CDL test in a 28 foot trailer if you want.
  6. rogueunh
    rogueunh Road Train Member
    1,082
    22,228
    Jan 4, 2011
    This statement couldn't be further from the truth.
    I took my CDL A test with a 40 foot tanker.
    I brought my friend who works for Coke, he took it with a single axle tractor and a 28 foot trailer.
  7. Allow Me.
    10,677
    12,240
    May 28, 2009
    Rancho Mirage, Ca.
    Correct, single screw day cab and 28' trailer, (semi trailer)
  8. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    Yeah I think the minimum is 28'. I was going to say 26' but I think Allowme is right. Has to have airbrakes too. So you can't use one of those race trailers with regular brakes. Doesn't have to be a manual transmission though. Can be automatic.
    If you already have a job lined up this is fine but if you are considering going over the road or driving for a company you will need to go through a school to get your license. Most companies nowadays require you go through an accredited school.
  9. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    1) There is no such thing as a combination endorsement
    2) Trailer length is not a consideration for a CDL. For a class A CDL you need a truck/tractor combination vehicle with a gross combination weight rating of 26,001 or more pounds, with a trailer(s) with a GVWR of 10,001 or more pounds.
  10. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    In this case a trailer with air brakes would be preferred but there are plenty of hotshotters out there that got a CDL A using a trailer without air brakes . Their CDL has a restriction for non air brake operation only . There is no air brake endorsement . Testing with air brakes will get the restriction removed .
  11. jamesh1979
    jamesh1979 Light Load Member
    64
    28
    Mar 9, 2011
    minneapolis,mn
    the last two posts are right make sure you get the asir brake endorsement as all new trucks must have them
