New owner operator, top 5 veteran tips?
Discussion in 'Ask An Owner Operator' started by Charlie Best, Jul 8, 2019.
  1. Charlie Best
    Charlie Best Light Load Member
    70
    80
    Jul 8, 2019
    Iowa
    I'm new to the forums here. I've been driving with a bigger company that I hated for the past three years, and finally decided to pull the trigger and become an owner operator. What are some top pieces of advice the owner operator veterans could offer me?
    Farmerbob1 Thanks this.
  3. Ridgeline
    22,736
    123,604
    Do your homework long before you even start looking for a truck.
  4. Chinatown
    Chinatown Road Train Member
    77,815
    184,859
    Aug 28, 2011
    Henderson, NV & Orient
    Become a member of www.OOIDA.com which is a business website for the owner-operator.
  5. D.Tibbitt
    157,255
    Win the lottery and turn in ur cdl
    PE_T, BoyWander, MartinFromBC and 4 others Thank this.
  6. DUNE-T
    DUNE-T Road Train Member
    7,054
    17,192
    May 10, 2015
    Detroit, MI
    Leased to someone or own authority?
    PE_T and Farmerbob1 Thank this.
  7. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Invest in proper tools to do the bulk of your repairs. Every thing from brakes to engine repairs to whatever. If you pay someone to do the work, you will not make ends meet.
    What is the year make and model truck you bought
  8. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    Have a good amount of money saved up before you start this adventure .
  9. 201
    201 Road Train Member
    12,794
    26,327
    Apr 16, 2014
    high plains colorado
    See my post on a 2020 Pete. You'll be changing your mind toot-sweet,,,
  10. runningman0661
    5,325
    15,878
    Mar 5, 2009
    Clover, South Carolina
    Put money away for taxes, maintenance and a rainy day fund.
  11. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,794
    Jan 17, 2017
    Unless you are a diesel truck mechanic, avoid buying used trucks from megas.
    If a mega's truck is low mileage, it has been wrecked, or is a lemon.
    If sold normally, a mega will run the truck 400k miles, doing as little maintenance as they can possibly get away with. They sell it to you, and you end up paying to do the deferred maintenance that they chose not to do.
    If you absolutely must buy a used mega truck, I strongly suggest you find a company that operates trucks with the features you want, and ask them to hire you and put you in a high mileage truck, and tell them that if the truck drives well, you may buy it after 50k miles or so. This will allow you the opportunity to get an oil sample and do a dyno on the truck (at your cost) to see if the engine has any existing obvious issues. If the truck is junk, you simply don't buy it, and if they won't put you in a different truck, give them notice and do the same at another company.
    Do not buy a modern emissions truck from Crete Carrier, or any other company that uses Opti-Idle instead of an APU. Opti Idle puts a LOT of low-temp operating hours on your exhaust system, which causes early wear and tear on your emissions systems.
    I bought a Crete truck. The engine and transmission are still fine, but I have been throwing money at the truck left and right to catch up on deferred maintenance on top of expected maintenance. I barely dodged a nasty bill when my Detroit Diesel emission system One-Box unit was replaced with 499700 miles on the truck. 300 miles from the end of the warrantee, and the shop advised that what they did would have run me 12k outside warrantee.
