New security flaw in credit card chips revealed
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Mark Kling, Aug 4, 2016.
  1. Truckers Report Jobs
  2. Puppage
    Puppage Road Train Member
    4,263
    7,370
    Aug 2, 2012
    Connecticut
    Another reason to use cash when you can.
    G13Tomcat Thanks this.
  3. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    These chip cards are useless in an age where many people buy things online and all the card detail, often including the CVS code, get placed on another computer system... Uhhh. Hello?
    LindaPV Thanks this.
  4. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,424
    Dec 10, 2011
    Weed, CA
  5. Starboyjim
    2,039
    1,424
    Dec 10, 2011
    Weed, CA
    Also, sorry, I forgot, just how does the magnetic code rewrite happen? How do the bad guys do it? How do they get access to that strip, from the reader?
  6. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    The strip is just a piece of cassette. Like how they storage music but instead an audio file of your information. And yes it does play a sound if u take the strip and play it on a cassette player.
    Basic audio change to digital, just like how 56k Internet work, if u pick up the phone while someone was on the internet, it make a werid sounds.
    So basically hackers and take that sound bit and just make a new tape and put it on a card. Doesn't even have to be a real card, a square cut out of cardboard could work too..
    To access the strip of data, hackers use a card reader that's put on top or in front of a real card reader. For example an atm machine. While you stick your card in, it will read the hacker's card reader first, then the real one secord.
    Ita like something like this. Also called card skimmer.
    The chip card is encrypted. Making it harder for hackers to steal your information. The link posted only show the flaw of the magnetic strip, and how it can still be hack and make the card reader thinks that swiping the card is the only way.
    Europe had this technology a long time ago. They already switch over making the United states the last big economic country to apply the chip card.
    Starboyjim and x1Heavy Thank this.
  7. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Also squeaking out what I know of computers, these cards generate a one time key which is a number that is about 255 characters long. once the chip generated this key it literally asks the Master server (Your card issuer) if they have a same key number for that specific transaction taking place now.
    If both agree, then it's approved and that is discarded never to be used again electronically. The large number key.
    I like them. But I keep them in Faraday cages now because some of the newer cards have ears inside and want to communicate with nearby devices that have ears also.
    You can literally buy a laptop, put that in your backpack, and a 60 dollar sensor that will have you walk down say a cafeteria line inside a truckstop or a College eating place and harvest the cards off those which are calling for communication with other towers and devices to make a sale.
    But you wont have that key and chances are you cannot use it.
    There was a ... hack not long ago where Apple Phones uses a Infrared Heat Sensor on the camera lens so you hover over the keypad of the cash register in the walmart and notice via temperature differences in time the 4 digit pin of the person in front of you.
    This is why I place my palm over the entire keypad to essentially heat it all up a moment and destroy any chance of harvesting the pin off me this way....
    Starboyjim Thanks this.
  8. KMG365
    KMG365 Light Load Member
    146
    249
    Aug 11, 2014
    If you have a chip enabled card, you should use it where offered. The chip is still superior to the magnetic stripe.
    This article makes some broad assumptions.
    It is true that the implementation of chip-based cards has been haphazard at best.
    Most US card issuers aren't requiring a PIN as part of the implementation of chipped cards either as the UK did.
  9. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    The strip is encoded to tell the reader to use the Chip. They get around this by encoding the strip with the CC info. The article states that the reader for the most part are not encoded so anybody can get this info by skimming and then build their own CC's.
  10. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    WalMart sued Visa over this. It costs WalMart about $00.04 per transaction if they sign or use a chip reader without a pin. WalMart in Canada stopped allowing VIsa not too long ago.
