No power to left turn signal on trailer or at fuse box on tractor.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Edjahman, Mar 8, 2020.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    I have a 2018 Peterbilt 579 and recently it was blowing fuses for the left turn signal on the trailer.
    The fuse for this, strangely enough, is in the fuse box on the firewall of the tractor.
    For several days, I thought it was in the trailer and had it looked at several times.
    Finally, it quit working altogether and it has no power at the fuse box or the trailer cord. I traced it from the rear up to where the DEF tank is located and it's also with no power.
    I'm assuming it's a completely broken circuit at this point and I'm sure it's in between where the DEF tank is and the fuse box on the firewall.
    I've never seen anything quite like this before.
    Does anyone here have experience with this sort of thing? Any ideas?
    It's looking like I'll have to go to Peterbilt unfortunately.
    Thank you
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,517
    6,576
    Aug 26, 2014
    Probably yes on the dealer.
    A little different model but one here had a bad control module. It is mounted on the drivers side frame rail behind the transmission. If spsaucerland and or GoodySnap come along they probably have better information. Module cost about $900 which would be an expensive pot shot without having everything tested first.
    Edjahman Thanks this.
  4. Edjahman
    648
    444
    Apr 2, 2013
    OK thank you.
    Obviously I'm out of service and I guess I'll go to Peterbilt in the morning.
  5. Judge
    89,692
    Just remember the hand signals, yes they’re still a legal form, or you could get a ticket, turning without a signal/improper lane change..$138 in Arkansas..
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    If you need a wiring diagram please post last six of VIN.
    SAR, pushbroom and Edjahman Thank this.
  7. Deere hunter
    2,118
    9,986
    Aug 5, 2017
    Shallowater Texas
    Tail lights on truck especially after winter running are a problem spot for me!
  8. Edjahman
    648
    444
    Apr 2, 2013
    Thank you for offering. Peterbilt is tearing the harness apart because they can't find it so I'm really boned.
    Yeah happy Monday.
    Thank you for your reply!
    Deere hunter and spsauerland Thank this.
  9. Edjahman
    648
    444
    Apr 2, 2013
    It was in the harness around the transmission. Wiring rubbing together.
    It cost a ton of labor to finally find it.
    Can't drive around with no left turn signal on the trailer though lol.
    BoxCarKidd Thanks this.
  10. Deere hunter
    2,118
    9,986
    Aug 5, 2017
    Shallowater Texas
    Wiring is always so labor-intensive but sure glad to hear you got it fixed and back on the road happy trails!!!
