There’s a “Bob is the oil guy” resource that may help you go further down the rabbit hole.
I wonder if there are large fleet analysis on this subject (not that they’d share to us Outlaw single operators .
Oil Analysis (lead and fuel)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by God prefers Diesels, May 27, 2022.
Page 3 of 4
KB3MMX, Siinman, Rideandrepair and 1 other person Thank this.
What truck/engine combo are you looking to upgrade to?
Siinman, Rideandrepair and God prefers Diesels Thank this. -
or
KW W9L
Twelve-seven
Pre-DPF, (preferably pre-EGR, but I don't really care about EGR as much.)
blairandgretchen, Siinman, JoeyJunk and 2 others Thank this. -
I know how it sounds, but this is exactly why I don’t do oil samples. I did one on my Truck after I bought it. Right about 100k on the inframe. Then another at around 1.1 mil. Both were almost identical . I plan on another soon. I now have 100k once again on an inframe. I look for shavings on the plug magnet. Also fuel in oil by drops of oil on a paper towel. Any fuel separates out quickly, Oil changes at 12k are fine. As long as oil pressures good, and it’s not burning a lot of oil. Run it. Even if it’s burning oil, keep oil in it, and run it. Not much else you can do, at that mileage. Rods and mains, if oil pressures low. Or just for peace of mind. Maybe a couple oil changes at 8-10k to clean it up a bit, if it’s dirty. Otherwise trying to watch those numbers will drive you wacky. Cause more anxiety than it’s worth. I see no coolant in the sample. That’s most important. You know it’s on borrowed time. If it fails, due to a bearing or head gasket, it will just happen. Oil analysis won’t be of much help.
blairandgretchen, BoxCarKidd, Siinman and 1 other person Thank this. -
You can run yourself looney by running samples and comparing them , seeing this sample being different from the others. I’ll guarantee when you change brand of oil it will start using oil. All manufacturers have a little something different in their oil, it’s okay to change viscosity but, not brands. Having dealt with this on numerous occasions over several years. Your piston rings are seated to a particular oil additive, they’ll loosen up and it will take time to reseat. We take samples to look for antifreeze and fuel if it’s suspected., otherwise when the filter is removed, it’s cut open and the element is spread out to look for metal or other foreign material. You should see normal wear but not larger pieces . If the oil pressure is good, (with no fuel or water ) run it. You may need to change oil at 5-8k for 2-3 times before it gets back to normal oil consumption. I run mobile 1300 15/40 in a 3406 c , made the mistake of adding a little something extra and it started using more oil ,now after 4 changes, it’s back to normal.
God prefers Diesels, blairandgretchen and Rideandrepair Thank this. -
Leaving wear materials in the oil is counter productive for lubrication and wear reductionGod prefers Diesels Thanks this. -
The big thing that used to affect motors was the vastly different seal swell additive concentration, things have changed a bit in addition to the new high temp durable anti wear additives that replace zddp and do a much better job under high heat loads.
Yada yada lol
Also agreed that you should start with good oil and skip all the additive scams.
The Lucas oil scam is one of the biggest in trucking. Horrible predatory company IMO.God prefers Diesels Thanks this. -
Page 3 of 4
