Oil change interval
Discussion in 'Ask An Owner Operator' started by mitmaks, Dec 31, 2016.
  1. mitmaks
    mitmaks Road Train Member
    2,544
    2,065
    May 16, 2014
    I had oil change done at local Speedco yesterday, did oil analysis as well which I could upload on here.
    According to oil analysis oil doesnt show any unusual wear, etc and Ive only had 15,000 miles on it. Its 15w40 Delo 400 that I run in Cummins ISX15 @483K miles on it.
    I was thinking should I extend it to 20K miles and do another oil test. Previously as company truck they changed oil @30k mile intervals on this truck but I've noticed oil consumption after @20K miles so I think oil would degrade at 20K miles and this is probably when oil should be changed.
  3. Steel Tiger
    Steel Tiger Road Train Member
    2,665
    3,221
    Jun 6, 2012
    Orlando, FL
    Every truck engine and every warranty stipulates different intervals. Factors such as type of use, road/off road, idling time can contribute to the longevity or lack of when it comes to pm service life.
    Filters are another aspect. Some may need a fuel, engine coolant, water separator filter with every service or every other service.
    Your best bet, if the engine is still under warranty is to follow the manufacturers guidelines so as to not void the warranty.
    Doing PM services way before they are due is a good way to spend extra money that you don't need to.
  4. frt60
    frt60 Medium Load Member
    312
    266
    May 22, 2014
    I change oil and filters at 20,000 than chnge oil and fuel filters at 10,000 that works for me
  5. Dave_in_AZ
    371,624
    I did my Volvo at 25K. 15-40 Mineral ( Delvac )
  6. stayinback
    stayinback Road Train Member
    3,911
    8,255
    Jan 24, 2014
    chicago,il
    Don't know much about the newer motors myself- But Im fairly Anal on service....
    Oil is changed every 8-10k ,Grease is every week, And Yes,It "Takes" it every week
    Ive got an older c-12, And an N-14
    bzinger and Dave_in_AZ Thank this.
  7. 77fib77
    77fib77 Road Train Member
    10,185
    62,903
    Jul 7, 2010
    St Louis
    I change it 12 to 18 k. At 18k the oil pressure drops on my engine running down the road. I shoot for 15 k. It's cheap and why have dirty oil running through the turbo? If I'm sitting in the Dakotas looking for a load out, then I'll change it early at 12k..
    Lepton1 Thanks this.
  8. Ridgeline
    22,142
    113,501
    Once your oil hits 5k, it is dirty.
    It is the additives that break down that is a concern. Oil doesn't.
    One reason why I install bypass systems on all the trucks is to keep it cleaner than it would normally be plus allows me to add additives back into the oil without the need of changing it.
    daf105paccar and 77fib77 Thank this.
  9. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Sure, go ahead and extend those oil drain intervals.
    Let me know how that works out for your ISX!
    cnsper, stayinback and Lepton1 Thank this.
  10. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    The first thing you need to do is get a real oil sample done. Not Speedco, Petro, etc.
    Studebaker Hawk Thanks this.
  11. Liquidforce
    Liquidforce Light Load Member
    273
    285
    Sep 27, 2016
    Savannah GA
    Does anyone have on file the accepted limits for an oil sample for an ISX and DD15, I haven't been able to locate it so far.
