Onan QD 7500 no power to start switch
Discussion in 'Trucks [ Eighteen Wheelers ]' started by blairandgretchen, Feb 25, 2018.
  1. blairandgretchen
    13,240
    70,603
    Dec 9, 2011
    South west Missouri
    Didn’t see a separate section for generator issues, maybe someone here has more experience.
    7.5HDKAT - 41934R
    Has 4000 hours on it.
    Changed oil and filter on it last month, then hadn’t used it since. Went to start it using the Command 30 remote - no start, no red light on switch when pushed.
    Go to unit - no red light when switch pushed to prime or start. No fuel pump clicking - nothing.
    3 DC fuses under switch panel good, and 13V to either sides. AC breaker on. Pulled rocker switch and tried another. Same result.
    13 V to starter solenoid. All good.
    Looking at the block that connects to the back of the rocker switch, it’s a block of 8, of which 5 have pins in them.
    Top left and Top Right are ground. Next 3 down on the right are, 10.2V - GROUND - 10.2V.
    I’m wondering if there’s a protection circuit that’s grounding one of these pins - like a low oil pressure switch.
    Like I say - no red light at switch,
    I replaced the high temp coolant sensor a couple of months back, as it would intermittently shut down. That fixed that problem, and I ran it 100 or so hours afterwards.
    Any help would be greatly appreciated.
  3. JackZ
    JackZ Bobtail Member
    24
    6
    Jul 7, 2011
    Winston-Salem, NC
    The first thing I would check is to make sure it's got good clean positive and negative connections to the batteries. If it does, I suggest disconnecting the remote switch wiring from the generator (it's probably connected with a Weatherpack connector) and then see if it will start using the switch on the generator. If it still doesn't start, I'm pretty sure the start switch light should blink with a trouble code and you can look that up to see what it means.
    And if you can't figure it out, you can call 1-800-CUMMINS (1-800-286-6467) and speak to someone in tech support. I've done that a few times over the years for our Quiet Diesel generators and they've been pretty helpful.
    blairandgretchen Thanks this.
  4. blairandgretchen
    13,240
    70,603
    Dec 9, 2011
    South west Missouri
    Oh yeah. Been through all this and some. And thanks for the response, by the way - I even joined an RV forum and posted this question - zero help.
    FOUND THE PROBLEM!
    And there’s the solution!!!
  5. Tug Toy
    Tug Toy Road Train Member
    6,932
    72,427
    Jul 4, 2015
    Corn field
    Looks like a serious solution!!! Repacking the whole unit seems a bit rash? Lol
  6. blairandgretchen
    13,240
    70,603
    Dec 9, 2011
    South west Missouri
    More details later. But it’s a pricey convenience.
  7. blue_gt
    blue_gt Bobtail Member
    5
    Jan 27, 2019
    What was the problem and the fix?
  8. blairandgretchen
    13,240
    70,603
    Dec 9, 2011
    South west Missouri
    Shot you a PM.
  9. Ghobbs
    Ghobbs Bobtail Member
    What was the problem. Im having the same issue. No light on my switch
  10. blairandgretchen
    13,240
    70,603
    Dec 9, 2011
    South west Missouri
    A1C main board. $1600+
    bzinger Thanks this.
  11. bzinger
    bzinger Road Train Member
    16,599
    65,787
    Dec 10, 2014
    omaha , ne
    I got tired of alternative apu solutions that always had some pia to go with it ....gas cans etc .
    Electric apu was a pos .
    Finally surrendered and bought a carrier diesel apu and happy with it.
