Opinions on securement of a load.
Discussion in 'Flatbed Trucking Forum' started by blairandgretchen, Apr 1, 2019.
  1. blairandgretchen
    13,667
    74,385
    Dec 9, 2011
    South west Missouri
    I've hauled similar pieces before, and had some damage.
    Here's the deal.
    They're steel pipes, with insulation around most of it. The insulation is just some hard foam wrapped with the very thin metal banded around it. The shipper says "Can't strap over the insulation - if you do, it's only for show"
    Which leaves about one point on the load where the gaps meet up and I can crank the heck out of a strap that goes directly to steel, (in this case, it's the one right at the rear - I heaved the tar out of that one.)
    This time, the pieces have the little 'feet' on the bottom, sitting on the 4 pieces of dunnage. However the rest of the straps are only just tight - very careful tension applied or the insulated parts would crush.
    There's 4 2" straps tied back to the rails to "keep 'em separated" - that's what damaged them last time - flanges and sharp stuff punctured the insulation. But they're only offering outward force.
    Aside from having the shipper crate these, or build custom bunks for them - any other suggestions? Apart from the obvious 'leave yard and return home'.
    Load weighs 8k lbs all up.
    It bothers me that this place continues to expect damage free, safe transportation of their product but refuses to listen to logic - but that's another old story. Load was inspected by the customer rep on-site, who wasn't happy with the straps being on the insulation, but it's like WTF do you want me to do then?
    4724B581-CEE5-44E2-8CBA-16028040A1C3.jpeg C0C70536-E342-452C-9B43-318233A968A0.jpeg 6ADF4245-5CB8-4B17-ACE8-9C6D8541CC85.jpeg
    Reason for edit: Information.
  3. Humblepie
    Humblepie Pontificator
    5,077
    80,318
    Dec 25, 2018
    I think it’s fine. They have those square brackets at that the back, I assume they have them at the front. So they shouldn’t roll.
    jamespmack, sawmill, cke and 9 others Thank this.
  4. Humblepie
    5,077
    80,318
    Dec 25, 2018
    If not some chock blocks nailed to the 4x4 will do the same job.
  5. HillbillyDeluxeTruck
    5,941
    30,369
    Mar 3, 2013
    San Antone
    Blair, we have a threa for showin off your flatbed loads, lol.
    jamespmack, cke, Grubby and 6 others Thank this.
  6. PoleCrusher
    PoleCrusher Road Train Member
    7,503
    82,194
    Aug 26, 2014
    LLMF
    Only thing I'd like to see some blocking in between and a couple belly wraps pulling them together. Yeah mr shipper we get it you don't want them together, that's what the blocks are for, blockhead.
    jamespmack, cke, Grubby and 10 others Thank this.
  7. blairandgretchen
    13,667
    74,385
    Dec 9, 2011
    South west Missouri
    Sorry - had to add text on the PC instead of the phone.
    I did use chocks last time, they punctured the insulated part.
    Lepton1, jamespmack, cke and 8 others Thank this.
  8. blairandgretchen
    13,667
    74,385
    Dec 9, 2011
    South west Missouri
    Yes, I hadn't been invited to the cool club yet - and this is absoulutely not a 'show off' load - I feel shameful pulling a load down the road that I personally haven't heard an A sharp 5 octaves above C resounding from every securement piece :)
  9. Espressolane
    18,278
    113,812
    Looks like it should ride ok as is.
    A few things I do on something like this.
    Spacer blocking between the pieces at the dunnage.
    ( hard to tell how far part they are)
    Then your choke wraps could go over both pieces, squeezing them together and holding the spacer blocking in place.
    jamespmack, cke, Grubby and 4 others Thank this.
  10. blairandgretchen
    13,667
    74,385
    Dec 9, 2011
    South west Missouri
    Good point - block between the feet then pull pipes together - form one unit/tie 2 together.
    This is the "Don't call us EVER " shipper - no load details, dims checks, appointment - NOTHING. I'm always totally blind going in.
    Lepton1, jamespmack, misterG and 9 others Thank this.
  11. blairandgretchen
    13,667
    74,385
    Dec 9, 2011
    South west Missouri
    Oh - that's the problem with the spacer blocks, is that the only bare pipe sections that match are the ones at the rear - so it would 'jaw' apart - any real pressure applied to the insulation crushes through. You can cut the sheet metal they use with a razor knife no problem.
    Lepton1, jamespmack, cke and 6 others Thank this.
