Opinions On Ultrashift Transmissions
Discussion in 'Flatbed Trucking Forum' started by unified88, Sep 26, 2012.
  1. unified88
    unified88 Bobtail Member
    We are looking at picking up a couple 2009 T660s with Ultrashifts. Does anyone have an opinion?
  3. Espressolane
    18,264
    113,684
    What will you be using these for?
  4. dirtyrabbit
    dirtyrabbit Medium Load Member
    416
    158
    Jun 19, 2011
    KS
    You lost me at '09! DPF is not my favorite term to hear. But, I am interested in hearing of an ultra-shift.
    SHC Thanks this.
  5. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    RUN AWAY.....
    2009, DPF. Why do that to yourself?
    Ultrashift is not a bad deal if you are always loaded and only OTR. They do not work for parking mobile homes thats fo' sho'. You cant move less than a foot at a time.
    Fot those of you who will inevitably say "just have the DPF removed"... EPA has gotten wind of that little plan, they are trying to find (and they will) a lawmaker to sponsor a bill making it a criminal offense and requiring a state certified "snag check" type inspection when you buy a DPF/DEF truck.
  6. Catfishbilly
    Catfishbilly Bobtail Member
    49
    29
    Jun 24, 2011
    Atlanta, Ga
    Screw ultrashifts, pansies.
  7. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    I drove a centrury for two weeks with an ultra shift in it. It wasn't too bad until ot came to backing. It was horrible. Also, going through an intersection once while making a left hand turn it dropped into neutral and wouldn't come out. After that incident I got a different truck.
    Ethan
  8. Gentlemanfarmer
    Gentlemanfarmer Medium Load Member
    365
    384
    Feb 26, 2010
    Greenville, FL
    I have a 2007 Volvo 780 with an Eaton Ultrashift. It is a 75/25 relationship. 75% of the time I like it, 25% I hate it. It definitely sucks when trying to back a heavy load (I am a flatbedder) and it will often stick in second unless you come to a complete stop. I have had problems lately with it down shifting while climbing uphill and not being able to up shift again. I have to go to manual to up shift and then put it back in auto. I have a feeling that the speed sensor is going out again.
    If I were to buy another truck today, I would have to say I'd go back to a manual transmission. I have much better control over the truck overall. The best thing about the Ultrashift is when stuck in traffic, you don't have to clutch and going downhill, your down hill velocity will not over rev the engine.
    Hope this helps in your decision. Oh yea, almost forgot. I don't recommend a 2007-2010 KW t-660. From what I have heard from fleets, the engines on these things suck and require a lot of down time. You would be better off buying a pre-2006 model or a post-2010 model.
    SHC, The Challenger and DrtyDiesel Thank this.
  9. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,618
    Oct 23, 2009
    Alexandria, AL
    I have a 07 780. My best advice is to avoid the ultrashift. They are a big headache. Sometimes they will go into a fault when going down the road(meaning the Service light and a "F" flashing in gear display, and when it comes out, it will sometimes do a hard shift jolting the truck). Sometimes when you park, the transmission and the computer don t communicate and you re stuck with a (-) in the gear display, and since it isn t in neutral, the truck won t start.
  10. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    The Volvo ISHIFT which is exclusive to Volvo engines and obviously Volvo trucks is the cats meow, I have a 13 speed now.....my next truck if it's a Volvo will probably be a ISHIFT, it's a night an day difference to the eaton autoshift or the Merritor automatic
  11. Gentlemanfarmer
    365
    384
    Feb 26, 2010
    Greenville, FL
    Did you test drive the IShift or driven one under a load. I have heard great things about them, but won't buy one unless I can test the truck under a load or hear multiple good reports.
