Oranges
Discussion in 'Refrigerated Trucking Forum' started by LandslideRich, Feb 5, 2018.
  1. LandslideRich
    LandslideRich Light Load Member
    292
    268
    Jan 13, 2017
    Charlotte, NC
    I've never hauled citrus before, so please forgive my ignorance. I usually haul more sensitive commodities because they pay so much more.
    I'm at a shed that wants to load oranges at 65 pulp and have me run it at 40. The receiver has already signed off on it but I'm still worried about my unit freezing or just plain working to death. The load delivers in 5 days. Should I be worried?
    ReeferRick Thanks this.
  3. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,409
    Aug 28, 2009
    Airlie Beach QLd
    You make sure you run it at the temp specified by the shipper if they say 40 f then 40 it is. If your reefer motor is running properly there's no issue it will either warm it up if the temps are to cold or cool it down if the temp is to high. The other thing to make sure you get temp check on the product as its loaded cause your reefer will only maintain the temp its loaded at so if its rejected you'll get the blame, however if the temp is high before loading and you refuse it then its on the shipper.
    jammer910Z Thanks this.
  4. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,685
    16,230
    Jan 18, 2011
    Set it where they want it.....Soon as your loaded and close your doors Open your vent door...,as you get in set unit up to 58 continuous.....ride for an hour and check...,if it's close...drop 3-5 degrees more..,.continue process.,...till(if u ever) get to 40
    Normal procedure If you leave it at 40 Unit is gonna work its ### off building moisture defrosting (and of course raising temp in doin so) and might never get down.,,,,.
    Done it hundreds of time....weather u ever get to 40!depends entirely on how far your going and moisture content of fruit
  5. LandslideRich
    292
    268
    Jan 13, 2017
    Charlotte, NC
    I don't have a forward vent. Just an inspection door on the back. Oh well.
  6. Cat sdp
    Cat sdp . .
    20,941
    72,805
    Apr 8, 2012
    Orion's Belt
    I know nothing but what happens when he gets to receivers and load isn’t at 40F.....
    Is the pulp at 65F at loading gonna save him....?
    Farmerbob1 Thanks this.
  7. LandslideRich
    292
    268
    Jan 13, 2017
    Charlotte, NC
    Receiver has already signed off on loading at 65. I have it in writing.
    Farmerbob1, ReeferRick and Cat sdp Thank this.
  8. ‘Olhand
    6,685
    16,230
    Jan 18, 2011
    You only need rear vent......it allows the flow out of the shoot to move the hot air out as it rises in wagon.....front vents serve different purpose....as for temp on arrival....as long as pulp temp at loading marked and signed your good....cooling all sorts of loads en route is nothing new....have a safe trip
  9. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Yea as long as it's noted and all parties know the deal just run it. Not a lot different than watermelon right out of the field. It's hearty enough it is fine. I haven't done much of these in quite some time now...enjoying life on the frozen side of things...
    Farmerbob1 and LandslideRich Thank this.
  10. Cat sdp
    Cat sdp . .
    20,941
    72,805
    Apr 8, 2012
    Orion's Belt
    Ya , but would you set at 40f right off the bat or work the temperature down slowly......
