over head panel lights not coming on and low oil pressure alarm is not sounnding
Discussion in 'Kenworth Forum' started by kimbo7, Apr 14, 2013.
  1. kimbo7
    kimbo7 Bobtail Member
    9
    Hello everyone, I am new to this site and I am trying to figure out why my overhead panel lights went out all of a sudden and my low air pressure buzzer doesn't sound when I first crank the truck up. It makes no sounds what so ever. I have a 2005 Kenworth w-9 with a c-15 cat motor. I have checked the fuses and wiring. Any suggestions would be greatly appreciated.
  3. Driver of the year
    Driver of the year Medium Load Member
    442
    249
    Sep 28, 2012
    Tampa FL
    It has to be a fuse somewhere. I was trying to connect my cb radio on the top console of my tractor and something went wrong, wrong connection and lost all gauges when i open the switch. Called Freightliner and a Service technician told me where to look. It was a mini 30 amp fuse. Now you say you lost it suddenly? if no help in here, i would call Kenworth tommorow.
  4. flyinsquirrel
    flyinsquirrel Bobtail Member
    6
    Nov 24, 2012
    it might be just as simple as your plugs on the backside that connect to them have come loose. something simple to check and only involves 2 screws. there are two plugs on the backside of those warning lights. hope it helps
  5. scottied67
    scottied67 Road Train Member
    10,826
    12,673
    Mar 14, 2010
    california norte
    Try the low air event again but with the driver's door open. Some reason the alarm on mine will not sound with the door closed but does with the door open. So when I do inspections, I leave the door open, usually have to anyway as the inspector is standing right there on the step looking in for the red light and alarm.
  6. kimbo7
    9
    Thanks for all the great advice I will try these suggestions and let everyone know what the outcome was.
  7. kwswan
    kwswan Road Train Member
    1,988
    10,756
    Jul 26, 2009
    mcminnville,tn.
    Look in the fuse panel for a fuse marked warning lamps & make sure it is good. This controls the overhead light strip.
  8. kimbo7
    9
    The only ones i lost power to were the check engine light, low air warning. They won't light up or make the buzzing sound.
