Oversize loads and car crashes ahead.
Discussion in 'Questions From New Drivers' started by WildTiger1990, Apr 7, 2021.
  1. WildTiger1990
    WildTiger1990 Heavy Load Member
    839
    1,418
    Apr 21, 2015
    So, I know I am not a new driver, but I wonder as rookie, what do truck driver do when carrying oversize (11+ feet wide , or with pilot escort) loads and there serious crash ahead.
    Most of the time IF WE ARE LUCKY, police blocking entire lane and half with cones and you can bypass accident at 5 mph with half way of a truck on a shoulder.
    But what if you have oversize , do you stop on shoulder and sending escort ahead to find out if you can fit, or you just going through and hope police will move cones for you that you can bypass?
    NavigatorWife Thanks this.
  3. Deere hunter
    2,023
    9,166
    Aug 5, 2017
    Shallowater Texas
    I’ve done both. Or sometimes get lucky find a short route around it. Sometimes you’re just stuck. The wider and heavier you are the worse it gets.
  4. TripleSix
    129,829
    11ft is no problem at all. If the road isn’t closed, keep going. Most states will start requiring civilian pilot cars at 12’-12’6 wide. A decent OSOW driver should be able to get a 13ft wide load anywhere that an ordinary truck can roll.
    Most States/Provinces will tell you as an OSOW driver to follow any detours that were set up to get around a crash. There does come a certain point, however, when the load is so big, and required so much trip planning, that you don’t dare jump off route to take a crash detour. I have had situations where I opted to stay on the shoulder of the interstate instead
  5. Frank Speak
    Frank Speak Road Train Member
    4,521
    13,825
    May 3, 2016
    I think about this as local tanker yanker because I sometimes have OTR types asking about this or that or wanting to follow me around construction or wrecks. I had a pilgrim wanting to follow me on a detour around a wreck one day. He radioed and asked if I was detouring around the wreck. I came back "Yup". He says I'm going to follow you if that's cool. I radioed back to him "If you're not yanking a tank, you better stay where you are, low bridge where I'm going".
    Moral of the story, you better not blindly follow the leader. What if I'd just said "ok" because I didn't think about the low bridge? There's one low bridge that I go under a couple or three times a day. That guy was just lucky that I happen to think about it. It's usually NOT something I think about.
  6. skallagrime
    skallagrime Road Train Member
    3,856
    9,943
    Apr 10, 2012
    Indiana
    Had a 100 foot crane beam, local police were routing everyone off i40 to a parallel us route in AR, had been sitting in traffic enough to look at the route, wouldnt make the sharp turns with as long as i was.
    When it came to the exit, i told the officer to just let me park beyond the exit ramp and wait it out, he at first told me i had to go that way, but i pointed out i would cause a bigger problem on their detour, he looked at my load, waved me ahead, 4 hrs later the road was clear.
    Sucked but at least i didnt mess anything up.
    (Long is a different animal than wide)
    Moosetek13 and TripleSix Thank this.
  7. Dennixx
    Dennixx Road Train Member
    4,479
    14,208
    Feb 13, 2010
    twin cities
    Last year was headed west on a 2 lane w a north wind.
    Came upon local police who had the road closed due to a raging car fire on westbound shoulder.
    They were detouring vehicles onto a 5 ton gravel highway. Told him I couldn't pass by the fire w my oxidizer load and would not risk the back road at 80K.
    He let me pull thru the detour and wait on the shoulder till the fire was out and the car was removed. If I sink or get stuck on a 5 ton road,even if I was directed on it guess who gets the blame..
    Less then an hour delay total.
  8. roundhouse
    roundhouse Road Train Member
    3,170
    7,209
    Jul 11, 2018
    We had a wide aircraft body once, and interstate was closed due to fatal accident and all traffic detoured.
    we just told em we were not permitted off route. They pulled the cones and let us park, by the time the road was opened four hours later , there were 8 oversize loads piled up with us.
    if you have an oversize / overweight permit from the state that tells you specifically what route to use, you need to think twice about going off route. some states we have a blanket permit and can use any road we want. Some states are very specific about what roads and what times of day we are allowed on that road.
    Some states we can exit and cross the interstate to a truck stop and some states we are not allowed to cross any bridge that’s not ON the permitted route.
    So we have to use a truck stop thats on the same side as the exit ramp .
    Dennixx Thanks this.
