overweight
Discussion in 'Refrigerated Trucking Forum' started by bigdad7, May 28, 2013.
  1. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    i am over 250 on drives and 350 on trailer .....can;t slide fifth wheel(it hasn;t moved in 3 years ) about 40 pds over gross i am sure that will burn off ....going from nogales to twin cities .....only scale i think i;ll cross will be in nm wil they ticket me over that much
  3. thedrifter
    thedrifter Medium Load Member
    522
    263
    May 23, 2010
    portland or.
    they may not ticket you but you will be hasseled. If i had that load I would make the fifth wheel move it doesn't take that much to do if the locking jaws have air to them it will move.
  4. Pete Moss
    Pete Moss Light Load Member
    144
    101
    Oct 28, 2011
    Phoenix,Az
    Hey-How are you?I wouldn't think by the time you get to Lordsburg it will be that big of a problem.You should burn about a pound a mile off.If you have pre pass that might help you get by.Don't stop at the next exit(Flying J/Pilot.There's weigh-in-motion when you get back on.I think you'll be ok.Take care.Brian
  5. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    Tried a few years ago it wouldn.t release let it go.bcuz i.ve not been grossef out in four years better get it looked at when i get home
  6. rodknocker
    rodknocker Road Train Member
    1,242
    584
    Dec 18, 2008
    Southeast
    I think you'll be fine. If not, just siphon some fuel in the parking lot when they give you an option to move the freight around. Might need to figure the price of fuel vs cost of ticket to see which is cheaper. I really doubt you'll run into problems. I got an 800 over the other day. I asked if I could step out of the truck and lift up on the bumper to get it closer. They said, "Nice try."
  7. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    Is that like the old chicken hauler that kept stopping on the side of the road beating his trailer to keep half the load flying?
  8. snowwy
    snowwy Road Train Member
    20,598
    13,319
    Jul 6, 2009
    40 pounds. but your a total of 600 on your axles. slide the trailer back. now your 600 on the drives.
    i'm guessing you lowered your landing gear to take the weight off the drives before sliding the 5th wheel? don't know you but most people don't realize that the 5th wheel won't slide with the weight fully on the drives.
    a 5th wheel that don't slide. and you've let it go for 3 years. instead of fixing it. and now your in a jam.
    i had that problem once. i disconnected the trailer and pulled from under. sprayed lubricant on the 5th wheel. used the whole can. and beat it with a hammer on the sliders. company didn't care to fix it. so why should i care. but i got it to move. and lock back in.
    desperate measures.
    or you could run around the scales.
  9. rodknocker
    1,242
    584
    Dec 18, 2008
    Southeast
    Lmao. I bet they never get the same reading twice with a chicken hauler with active chickens and big cages.
    379exhd Thanks this.
  10. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    Diesel weighs roughly 7 pounds per gallon depending on the temperature. It's roughly 220 to 250 miles to lordsburg from Nogales. You may still be over but this will help.
  11. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    Wont burn enough in the reefer for that my fuel tanks sit forward all that weights on steers .....but i did take my spare tire off trailer and secured it to sleeper si now 450 ovr on drived 100 on trailer noew i.ll have mt daughter make me a cardboard apu and we are good to go after lordsburg i.ll b home free a
