Paint on aluminum rim
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lazer, Mar 22, 2022.
  1. Lazer
    Lazer Road Train Member
    1,830
    2,940
    Jan 22, 2017
    Doing some wheel/tire switches today, got better arrangement now with tread depth, pattern etc., now we have one aluminum rim, facing outward and low and behold, in the past someone painted this rim black. Other than dismounting the tire, and switching rims, what’s a easy, effective way to remove paint from an aluminum rim? TIA
  3. John E.
    John E. Light Load Member
    239
    973
    Apr 4, 2021
    New Brunswick
    Oven cleaner may work for you. It is a very powerful cleaner.
  4. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Put it on the inside
  5. Lazer
    1,830
    2,940
    Jan 22, 2017
    I thought of that but that tire is a little bit more worn down than the outside one, and with the curvature of the road, I always figured if one just slightly taller, put that one on the outside.
  6. Judge
    90,139
  7. Lazer
    1,830
    2,940
    Jan 22, 2017
    Just to update, tried oven cleaner that was a no go. Evidently hi-temp paint must have been applied. Short of paying out of my own pocket for sand blasting, I switched rims, tire is in the same position, but now with a clean rim.
  8. AModelCat
    161,704
    I'd just hit it with a fine grit paper on an orbital sander and hand sand the hard to reach spots. Maybe a light polish to make it match the rest of the rims.
