Passed 2 out of 3 parts of road test. Class A
Discussion in 'Questions From New Drivers' started by Jcris4991, Jan 13, 2018.
  1. Jcris4991
    Jcris4991 Bobtail Member
    11
    4
    Jan 13, 2018
    In NJ I took my cdl class a road test. I passed the pre trip inspection and basic manevures but failed the actual road driving part. Do I have to take the whole test over again or just the part I failed? Can’t get find a straight answer. Thanks.
    x1Heavy Thanks this.
  2. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,751
    Nov 23, 2015
    Yes.
    Retake everything.
    rabbiporkchop Thanks this.
  3. x1Heavy
    x1Heavy Road Train Member
    18,156
    18,142
    Mar 5, 2016
    White County, Arkansas
    What part of failed don't compute?
    You will have to take it again. I think it's a certain amount of time to give it another go.
  4. bigkev1115
    bigkev1115 Road Train Member
    1,524
    1,713
    Oct 23, 2009
    Alexandria, AL
    How did you fail road test if you don t mind me asking
    Dan.S Thanks this.
  5. DTP
    DTP Road Train Member
    1,018
    1,793
    Dec 9, 2014
    My guess is he stalled the truck coming out of a stop. Either forgot to switch to low range or let off the clutch too hard. Happened to 2 guys in my CDL class way back when and had to retake it.
    bigkev1115 Thanks this.
  6. mitmaks
    mitmaks Road Train Member
    1,543
    821
    May 16, 2014
    In WA state you only have to retake part of test that you failed. IE if you failed driving test and passed pre trip and backing part then you only have to do driving test again.
    Oxbow Thanks this.
  7. C.S.T
    C.S.T Light Load Member
    125
    56
    Nov 15, 2017
    He might had ran the red light or hit a curve or stop in neutral. That's a automatic failed
  8. HarryW80
    HarryW80 Bobtail Member
    5
    From what my instructor told me at the school I’m going to, since you passed your Pre-trip and backing, you should only have to retake the road test. He is referring to what other students have had when they’ve failed the test, in NJ. Which DMV did you go to?
  9. BrandonCDLdriver
    BrandonCDLdriver Heavy Load Member
    856
    921
    Sep 1, 2017
    In LA you only have to retake the part you failed, but you can only fail it like once or twice then you have to redo the whole thing.
  10. DevJohnson
    DevJohnson Light Load Member
    256
    119
    Nov 27, 2017
    Or could have crossed over the yellow line when making his turns.. also now they’re getting you for coasting and not being in a gear at least 5 seconds from comin up to the red light
  • Draft saved Draft deleted
