Peterbilt tachometer issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 2006gmcdmax, Jun 27, 2018.
  1. 2006gmcdmax
    2006gmcdmax Light Load Member
    67
    26
    Jan 31, 2018
    i have a 96 357 the tach used to work then it wouldn’t then it would. Anyways when it stoped you could bump it and it would go to working. When you shut the truck off it go to 2500 when turn it on it goes below zero so it’s getting power. Any advice here?
  3. W900AOwner
    W900AOwner Heavy Load Member
    714
    1,284
    Jul 2, 2014
    You'll be best off to open the dash and access the back of the tach with a tester to check for continuity back to the sending unit first, to see if the wires are OK. At that point if they are OK I'd be looking at the tachometer head itself gone bad.
  4. 2006gmcdmax
    67
    26
    Jan 31, 2018
    Can you rebuild them or what actually goes bad
  5. kemosabi49
    10,453
    44,507
    Jan 13, 2013
    SW Arkansas
    I think I remember @blairandgretchen having a problem with his tach sometime back.
    blairandgretchen Thanks this.
  6. W900AOwner
    714
    1,284
    Jul 2, 2014
    I'd just get a new one from Pete.
    2006gmcdmax Thanks this.
  7. 2006gmcdmax
    67
    26
    Jan 31, 2018
    It’s crazy I mean you could barely tap it and it would go right to working no issue
  8. lowlife
    lowlife Bobtail Member
    21
    23
    Feb 21, 2017
    Minnesota
    Most likely the solder broke on the plug going into tach. Mine would do the same thing, ended up cutting the tach in half resoldered and gorilla taped it back together.
    Oxbow and blairandgretchen Thank this.
  9. RocketScott
    RocketScott Medium Load Member
    579
    946
    Apr 10, 2013
    Kentucky
    Same here.
    I took the time to pry the bezel open on the back side. Ended up breaking the glass. Local glass shop cut a new piece for $10. Quick solder job and carefully tap the bezel closed with a punch and small hammer.
  10. blairandgretchen
    13,242
    70,641
    Dec 9, 2011
    South west Missouri
    I might hack into the old one and see if I can repair it - may cut bezel with a dremel instead.
