Please help! Air brake leak detection / Service Center
Discussion in 'Questions From New Drivers' started by amber roush, Jul 31, 2019.
  1. amber roush
    amber roush Bobtail Member
    Jul 31, 2019
    Can someone please suggest a rv/ trucking service place that has an air brake detection system. An Rv has a leak in the air breaks. I am in Cincinnati Oh /45102. Thank you!
  3. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    Climb under there with a spray bottle of soapy water and start spraying.
  4. amber roush
    Jul 31, 2019
    Is that how everyone does it? Is there a such thing as an air line break detection system ?
    x1Heavy Thanks this.
  5. FlaSwampRat
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    You can smoke machine it but I would charge someone a fortune to do that. Your best bet is climbing under it with soapy water after the system is pressurized.
    amber roush Thanks this.
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Any truck repair facility should be able to find a air leak ... google truck repair near me and make a few calls . It will be Your easiest solution
    tscottme, Puppage and amber roush Thank this.
  7. AModelCat
    161,681
    Yup. Spray bottle of soapy water and a good set of ears. Don't need any fancy equipment. Not even sure there is even such a thing as an air brake leak detector?
  8. Espressolane
    18,284
    113,851
    Who is the manufacturer? They may have a list of service centers or a toll free number in the owners manual.
    The T/A, petro and loves truck stops do limited work on RV’s
    Truck dealers, like Freightliner do service work as well.
    You may be able to search your local area on google, to find a location of one of these types of facilities.
    tscottme and amber roush Thank this.
  9. FlaSwampRat
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    I have hooked my smoke machine I use to find intake/turbo/emissions leaks to air brakes before. It takes forever to fill the system and a ton of fog juice so it would be super expensive.
    amber roush and AModelCat Thank this.
  10. GypsyWanderlust
    GypsyWanderlust Medium Load Member
    386
    568
    Jan 1, 2018
    It is like looking for an air leak in a tire for a small leak so yes the spray bottle of soapy water is what you are going to pay a tech $90 an hour to use. You can usually hear a leak though and the most common place for a leak would be the fittings.
    All that being said, any truck service center with a mechanic can probably fix it. I would see if you can find the leak first before opening your wallet.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Thats how we did it.
    Under there you go. Start spritzing. Mr Bubble will tell you where it's at.
    Once you find Mr Leak and learn the affected part/system component etc you will understand the situation better.
    Our dear engineers spend time running hoses and building trucks to dazzle our minds. But they over think everything and you fall back to very extreme simple stuff to find Mr Leak.
    If you do Find Mr Leak, take pictures. Put em up and if there is something to be done...
