Please help!!
Discussion in 'Ask An Owner Operator' started by joe1989, Nov 2, 2019.
  1. joe1989
    joe1989 Bobtail Member
    13
    Fault 1 cab 33 spn 522120 fail 5, plus I don’t know where the coolant goes 100 percent no visible leak the oil looking good, coolant looking good , I appreciate it your help.
  3. Tx Countryboy
    Tx Countryboy Road Train Member
    1,968
    4,437
    Sep 18, 2019
  4. joe1989
    13
    Hello, freighliner cascadia dd15 2012
  5. Judge
    87,919
    Cab 33 522120 5 conn X20, pin 20
    Washer pump – Current below normal, or open circuit. C06.01 — Windshield Wiper/Washer G02.04 — SAM Cab
  6. SoCalRed
    SoCalRed Medium Load Member
    437
    851
    Feb 7, 2017
    CA
    Check for moisture in the EGR to intake pipe. If you see moisture in there you found your leak EGR cooler. Easy to replace on DD15.
  7. Concorde
    Concorde Road Train Member
    4,722
    16,870
    Jun 29, 2016
    West Melbourne Florida
    How much coolant are you losing..at what rate?
  8. Tx Countryboy
    1,968
    4,437
    Sep 18, 2019
    Not coolant - that's about washer fluid
  9. Judge
    87,919
    Thats what the code looked up, dont ask me, I am just the messanger
    Rideandrepair Thanks this.
  10. SoCalRed
    437
    851
    Feb 7, 2017
    CA
    From what I understand he has a code for the washer fluid and he is also loosing coolant and can’t see any leaks.
  11. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    There is a code for washer fluid??? lol
