Plugs for floor holes?
Discussion in 'Refrigerated Trucking Forum' started by gokiddogo, Sep 3, 2012.
  1. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    This might be a rookie question, but is there such a thing as plugs you can buy to put in the holes in the corners of the reefer floor? I ask this because I am hauling loads right now that are weighed at the shipper and again at the receiver and there is always about 1000 pounds difference due to water coming out of the product. I am very sure it would make the shipper very happy if I could retain greater payload when reaching the receiver's scale.
  3. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Maybe THIS?
    gokiddogo Thanks this.
  4. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Rubber freeze plugs, sell them in auto parts stores and they have a bolt with a washer to tighten them up.
  5. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    LOL, sound's like a terrible idea. So you want a thousand pounds of water to flood the trailer floor and possibly turn to ice? I'm sure that would make them happy. :)
  6. aiwiron
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    I was not going to say anything, but when shippers blow ice on things you pray it melts to lighten the load.
    123456 and VisionLogistics Thank this.
  7. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    If you were to do this, I would be very careful opening the door when you get to where you are going, I can't picture one thousand pounds of water so it might be nothing, but at the very least it might give you a bath, at the worst, if you are parked on an incline when you open the door with water pressure pushing on the door, you migth get a bloody nose from the door.
  8. Taildragon
    723
    449
    Jun 22, 2012
    Indiana
    There is one alternative, (if the water on the trailer floor won't damage the load), carry you a short length of maybe 3/8" pipe, "after you have weighed in", and "before you open the door", take the section of pipe and bump the plug up and out of the hole, but here again, bath time... but then are the skids going to be soaked and dripping?
  9. Winkjr
    Winkjr Road Train Member
    1,804
    614
    Oct 18, 2011
    Marlton NJ
    You don't need them unless you want what that other driver said a flood of chicken blood raining down on you when you open the doors. And the other guys right you want to lose the weight so let it drain.
  10. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    The load is bulk produce loaded directly on the floor. On the receiving end they float it out. Appreciate the replies. I am not the one who opens the doors, the mexican workers at the receiving place check seal and cut it off and set it up so they can float it all out.
  11. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    I forgot to add that it is running high enough ice is not a possibility.
