I'm new to the pneumatic world, but not a new driver by any means. What I am looking for is in regards to airlines for the pneumatic lids. If these lines, as opposed to brake lines, have a leak; or there is a leak at the the control panel is this an OOS?
Pre-trip question for pneumatic lines.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by SoulScream84, Mar 16, 2022.
SoulScream84 Thanks this.
Bean Jr., SoulScream84, D.Tibbitt and 3 others Thank this. -
SoulScream84 and God prefers Diesels Thank this.
As far as a leak not at a proper connection, I take that to mean a leak at a rubber brake line where it is crimped. At least I'd see that being the case 99% of the time. And it makes sense, because it's not something you can fix on the side of the road unless you carry a spare line.
Then the part about the diaphragm leaking audibly puts that brake at inoperative. So the problem there isn't so much that it's an audible leak, but now you have a brake that doesn't work correctly. But in that case, you're allowed so many brakes to not work, so you might be OOS, or you might not, depending on the health of the rest of your brakes.
I like this OOS PDF, because once a year you can spend a couple days with your truck, and give it a really comprehensive level 1. Once it passes everything in the PDF, you should be good to go. Then you could keep a copy of it in the truck to show the officer if there's a dispute. At least I like to pretend that's how it works.kranky1 Thanks this. -
TooTiredToTalk and God prefers Diesels Thank this.
Thanks for chiming in, something I've learned with these pneumatic trailers is that they have so many ###### spots that can leak it's difficult to find them all.
God prefers Diesels Thanks this. -
Boardhauler, God prefers Diesels and TooTiredToTalk Thank this.
You're talking about the air operated dome lids correct? If so, those have nothing to do with the operation of the unit while it's on the road. As long as they're latched you're good to go. If the control panel itself is leaking and it is resulting in a drop of air pressure at your tractor, then that is a violation. If the leak is after the control panel and only leaks when you put air to the lids, then it's not.
