Pretrip in Winter
Discussion in 'Questions From New Drivers' started by TravR1, Nov 28, 2017.
  1. TravR1
    TravR1 Road Train Member
    3,693
    9,581
    Nov 9, 2017
    TX
    i took a practice cdl test and a question asked which system should be looked at most closely in winter cold months. From the list, the answer was the exhaust system. I know exhausts can be dangerous when leaking, but why is it more dangerous in the winter? What would I look for
    Need4Speed Thanks this.
  3. Kyle G.
    Kyle G. Road Train Member
    3,849
    20,200
    Jan 23, 2016
    Eastern Iowa
    I forget what the technical reasoning is behind that. Maybe because in the winter there is a lot more idling and risk of carbon monoxide entering the cab. Also I suppose the colder temps make the exhaust pipes contract more when you shut down and thus more prone to leaking.
    SingingWolf Thanks this.
  4. WesternPlains
    6,298
    53,320
    Sep 1, 2017
    I can rationalize that the above answer is correct.
    I had problems with the exhaust where it connected to the filters. Lots of pressure when it goes into regen. Also in the cold. Everything falls apart. Comes apart. At 20 below, even the roads fall apart. I've experienced the danger of an exhaust leak under the passenger door of the cab.
    Otherwise... Lots of problems with the air system, fuel system.
    Fuel likes to gel up in the cold. Be careful. Stay on top of it. Use good additive. Having to change fuel filters due to gelling.... I know all about that.... Doh! You can build up condensation in tanks in the cold. Result is water in fuel or air lines. So make sure fuel tank is as full as possible if you're going to park for hours.
    Air system. Just a little water/condensation in there will freeze up and stop you from starting out. I've learned that draining the air system when you park, helps. Also, adding fuel line antifreeze to the air tank helps. You'll have to build up all the air pressure when you start up. That's far less hassle than dealing with frozen air lines.
    Kyle G. Thanks this.
  5. Ridgeline
    22,394
    116,378
    Why?
    Because the metal expands when it gets warm or hot and contracts when it becomes cold which can cause the system to loosen up.
    Lepton1, Dan.S, SingingWolf and 2 others Thank this.
  6. buddyd157
    buddyd157 Road Train Member
    13,564
    34,840
    May 25, 2017
    under a shade tree
    i concur. but it's always a good idea to take a look under the truck for any missing clamps that rust and fall off as well all year long.
    when you see black soot at any of the joints, have it taken care of ASAP. day cab, sleeper, don't matter.
    also, i'd recommend looking under the hood, and the firewall area for any missing body plugs, or cracks that can allow exhaust to enter from piping near the engine bay.
    another thought, i have read where many drivers of sleeper trucks, take along a CO detector as well.
    48Packard and TravR1 Thank this.
  7. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    I know in the summer, my windows are always open, so no chance whatsoever of CO poisoning even if the exhaust looks like swiss cheese. In the winter, windows are more likely to be rolled up, keeping any toxic gasses that leak into the cab inside the cab with you.
    Lepton1 Thanks this.
  8. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    If you are doing a proper pre-trip, seasons are irrelevant.
  9. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,764
    Mar 9, 2014
    In a van down by the River.
    So is focusing on one area. Should be focusing on them all.
    buddyd157 Thanks this.
  10. TravR1
    3,693
    9,581
    Nov 9, 2017
    TX
    That answer will not be on the test.
  11. Alaska76
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    I was not trying to provide a test answer for you. My point is one of reality. Understand that there are always test questions that are irrelevant and incorrect when it comes to real world application. As far as your test goes, study, study and study some more, maintain that discipline and you will ace the test/s.
    TravR1 Thanks this.
