Problems with trucks - APU/EPU, Collision systems... what are your experiences?
Discussion in 'Questions From New Drivers' started by Outdoorsman, Oct 10, 2012.
  1. Outdoorsman
    Outdoorsman Light Load Member
    142
    61
    Oct 24, 2011
    Ravenna, Ohio
    I'm still a student - still trying to make a choice about what company to go with.
    With the regulations, have come new technology being implemented on the trucks.
    No idle requirements have brought APU/EPU or opti-idle.
    Collision Detection Systems like OnGuard are becoming common.
    I want to be comfortable while I'm trying to sleep - I want the option of adding / having an inverter installed. Having creature comforts at the end of the day are important to me. Safety is critical to me, but a collision system sounds like it can be a PITA at times.
    It seems more companies are adopting these, and the industry as a whole is pushing them.
    But it seems that there are a lot of problems with these things!?
    APU (fuel operated), EPU (battery operated) systems, or opti-idle are designed to keep you warm or cool in the sleeper, instead of idleing... what are your experiences with them - what are the benefits / drawbacks?
    Collision Detection Systems are being ordered with new trucks, by a lot of companies. Some of them only work when on cruise control, while others operate at all times. The industry reports that rear-end collisions have been reduced significantly... and insurance companies are buying into it (true or not). But I've heard that these things react to 'ghosts' and will apply the brakes when approaching bridges or shadows. What are your experiences - are they really a benefit or just another hassle?
    When responding, it would help if you say what company you work for, and what kind of unit you're using / have used.
  3. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    When I get assigned a new truck, it will have the Collision Detection systems. My father in law drives for the same company I do and has a 2013 Volvo and says it drives you nuts in the city. Anytime I talk to him while he's driving, I can hear it beeping in the background.
    Outdoorsman Thanks this.
  4. Lady K
    Lady K Road Train Member
    We run for Central Ref... We have the On Guard system... We were one of the first trucks ordered with them as a trial... Now that we are use to it, it's OK.... Yes the beeping is irritating, but it only beeps if it deems you are too close the the vehicle in front of you... So back away, no more beeping. Nice in construction zones or in 'moderate' even flowing traffic, because it will maintain a select distance between you and the vehicle in front of you... Yes it will slam on breaks ... So you still have to be vigilant, and I just HOPE it puts the brake lights on when it does!! Also if you don't keep the Iceland bugs off the screen, it will get blocked and then neither it nor the cruise control will work.
    Would I specifically order one for my truck... Eh... Depends on the cost... Would I take one that is given to me... Yeah... Is it a necessity?? Nope...
  5. dirtyjerz
    dirtyjerz glowing beard pouty kid
    722
    360
    Jun 7, 2011
    Playing in Traffic
    I used to have the easton-vorad and hated it. It would beep at nothing, and i mean nothing. No cars, no bridges. Clouds? Maybe. Another driver showed me how to disable it so disabled it was. Imo you will pay much more attention to road road when you dont have the truck doing it for you.
  6. coopnp
    coopnp Road Train Member
    1,039
    454
    Oct 9, 2011
    Orlando, FL
    I work for Roehl in a 2012 Prostar. Our Cascadia's have them as well and they're some trucks in the fleet that dont have them. Luck of the draw what truck you get. At first before I moved into this truck I wasnt on board with the sensors and all that jazz. Then the older model truck I was driving had constant problems to where I moved into a new truck. My driving style the sensors dont really affect it at all being in mind I keep a good following distance and maintain my situational awareness. It is annoying to hear the beeping just have to back off not to hear it and can be a benefit to do so. I have the Bendix system and heard its better than the on guard but thats just hear say. The sensor would go out of alignment and have to get re aligned. When out of alignment it would fault and you couldnt run cruise control and not have tractor abs. Even when it works I dont run cruise bc really the computer may compensate for following distance but some situations like large hills or through the mountains you need that speed to crest the next hill or grade. It does tell you the speed of other vehicles around you and your following distance so you can make a out to avoid losing speed or momentum which is good. Overall I like it and dont mind it that much just some taking to get used to and make your driving habits good ones instead on instilling bad driving habits. The break check sucks when it happens but as long as your aware of your surroundings and traffic patterns you'll be ok. You slip and no pay attention then for sure it'll let you know
  7. musicgal
    musicgal Road Train Member
    1,171
    467
    Mar 8, 2010
    Carthage, Missouri
    Ran for US Xpress with the On-Guard on my 2012 Cascadia.....it was OK in that it regulated my speed (with the cruise on), which was nice......but it also slammed the brakes on for shadows or anything on the side of the road.
    Ran for Hirschbach with an APU on my 2010 Cascadia......it would run for about 6 hours and then I had to idle.
    Now I'm with D&D Sexton, 2009 Cascadia, and none of that stuff...but they don't holler when I have to idle.
  8. kf4omc
    kf4omc Medium Load Member
    330
    181
    Aug 24, 2012
    Clearwater, FL
    I drive for TransAm and the APU is great. Keeps battery charged and gives you ac and heat. TransAm also puts in a 3000 watt inverter so there is plenty of power in the sleeper. And one other thing they put in there trucks is Automatic transmission. (EATON 10 Speed UltraShift)
  9. Outdoorsman
    142
    61
    Oct 24, 2011
    Ravenna, Ohio
    You should change your Profile from 'Student' (to however much time you've been driving)... did you go straight from school to TransAm?
    I take it you also don't have any Collision Detection System on the trucks?
  10. Outdoorsman
    142
    61
    Oct 24, 2011
    Ravenna, Ohio
    Ok, so what about APU / EPU or Opti-idle?
    With the no-idle / emissions regulations - what do you have to do to stay cool in the summer?
    I've heard that one company tried APUs but they required so much maintenance, that the expense of repairs, wiped out the fuel savings?!
    I've heard some trucks have bunk heaters - but I'm guessing they draw on battery power - unless there is an alternative? I mean, if the battery runs out of juice for some reason, you'd be waking up frozen and no way to start the truck to get warm!?
    I guess you better have a really good sleeping bag, a few blankets, long johns and a snowmobile suit! :biggrin_2552:
  11. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    The bunk heaters are designed to draw minimum power plus they have built in low voltage cutouts. If it's cold enough to affect the batteries, you'd better be idling anyways.
