Qualcomm
Discussion in 'Questions From New Drivers' started by Commuter69, Oct 17, 2015.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    Ok... Short of throwing the thing out the window at $!!!÷ speed(I won't say what speed for fear of self incriminating evidence).....
    When the Qualcomm becomes non responsive (not in sleep mode)... How do you reboot it?
  3. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    You don't...you thank god and keep driving extra miles
    Chewy352 and Fire-Man Thank this.
  4. lots of character
    lots of character Road Train Member
    1,031
    1,814
    Aug 12, 2015
    I know this no help, but just disable the son of a ##### and spend $20 on some papered.
    But to try and help, what model Qualcomm
    25(2)+2 Thanks this.
  5. SuperTruckerinaVolvo
    SuperTruckerinaVolvo Light Load Member
    63
    105
    Oct 13, 2015
    Las Vegas, NV
    Find the appropriate qualcomm fuse, pull it out and put it back in again. That does the trick 99% of the time.
    Jubal3 Thanks this.
  6. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    7,678
    12,749
    Dec 15, 2014
    Charlotte, NC
    follow the cable there is a reboot switch there. Also not sure if it's a coincidence but every time my apu went out was after the qualcomm would not respond. After my Apu was reset it was fine.
  7. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    This does not always work, Mine is hooked thur the J Connection on the truck. Why it does have a ignition fuse it wont reset it just does not let it see the engine run time.
    You can call the omini tracks Automated help line and put the Unit Address (On the back of the unit) in and they will reboot it from the box in the dash.
  8. TripleSix
    132,810
    Several ways. Easiest way is to pull a certain 10 amp fuse in the fuse panelOr you can go to the main computer box (normally mounted in the side box) and disconnect the main cable. If you are adventurous, you will discover that there's another fuse that will make your Qualcomm power off and on, like it does when your engine is shut off for long periods. Pull that fuse, the Qualcomm will work to send messages, but the GPS won't work, elogs won't work, and you will be able to send messages. When it powers out of sleep mode.
    Straight Stacks Thanks this.
  9. dustingreenway
    dustingreenway Light Load Member
    63
    13
    Apr 17, 2015
    Atlanta
    On mine I hold the button with a head on it for 20 sec and it will reboot.
  10. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
    On the old ones we hit Control Alt Delete at the same time for a couple seconds. On the new one they said hold the home button for 8 seconds then the speech button for 8 seconds or some such combination to reset the unit. I also found that going into the side box and completely unplugging the unit cuts all power then re-plug it back together.
  11. TROOPER to TRUCKER
    7,678
    12,749
    Dec 15, 2014
    Charlotte, NC
    I tried all the button resets I think I searched on here (imagine that) but they never workded.
