Ratchet binders
Discussion in 'Flatbed Trucking Forum' started by jacquesi23, Mar 20, 2016.
  1. jacquesi23
    jacquesi23 Medium Load Member
    481
    159
    Jan 21, 2013
    What are some useful ways or techniques to keep your ratchet binders from locking up?
    You would think they would be more durable being that they are used outside.
  3. frt60
    frt60 Medium Load Member
    312
    266
    May 22, 2014
    Spray with lube before and afer use
    j_martell and Riprap Thank this.
  4. kw550cat
    kw550cat Medium Load Member
    663
    596
    May 22, 2012
    brooklyn, new york
    They are durable, if you oil them regularly. Just like a truck, it'll work and everything will spin, but you need to change the oil and grease it to make sure nothing seizes or burns up.
  5. Riprap
    Riprap Light Load Member
    286
    1,979
    May 31, 2014
    Saginaw, MI
    And keep them snugly closed in storage to keep the dirt from accumulating on the threads and more importantly, to keep the threads from wearing out.
    Are you having problems with the binders seizing up as you are tightening a chain?
    jacquesi23 Thanks this.
  6. blairandgretchen
    13,326
    71,423
    Dec 9, 2011
    South west Missouri
    Oil regularly as suggested. I use PB blaster and 3 in 1 oil.
    I'm sure anything would work, just a case of regular care.
  7. CJndaTruck
    CJndaTruck Road Train Member
    3,348
    3,364
    Nov 21, 2014
    Knoxville, TN (area)
    I use hub oil on mine. It's thick and last for months. As mentioned keep them closed to keep the grim out.
  8. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    I use snap binders, they are much more dangerous, and can do serious damage. However, they are a lot faster and don't require the amount of up keep as ratchet style binder. Price tag is also much lower.
  9. jacquesi23
    481
    159
    Jan 21, 2013
    I have a problem with them seizing up period. When I take them out to use them it's like wrestling trying to get them to unwind to prepare them for use.
    I think I'm gonna try that hub oil trick.
    I use dry lock fluid from time to time an it helps a bit but like anything else it dries out. I think my regimen is just off as far as how regularly i apply the oil
  10. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    A daily shot of CRC keeps mine working perfectly.
    Hurst
  11. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    I use hub oil in mine but I also take them out once or twice a year and clean them thoroughly. I screw them all the way out and actually take the ends out and clean the threads with a wire wheel. I lube them before hanging them up every time. I get a lot of mud and road grime on them.
    Mudguppy and Oxbow Thank this.
