Recent newbies
Discussion in 'Questions From New Drivers' started by 1278PA, Oct 24, 2017.
  1. 1278PA
    1278PA Road Train Member
    1,170
    1,026
    Dec 5, 2015
    Just curious how nervous were you the first time you drove these trucks on the road. First time backing in a truck stop to shut down?
    I'm thinking my first time I should wear a diaper that day lol. I remember when I got into the electrical trade about 20 years ago. The first time I worked in a live panel I was shaking and sweating bullets.
    My boss told me this...If you aren't nervous then your doing something wrong. Being nervous shows you are more concerned about what you are doing and more focused.
    I just know that first turn I make on a busy intersection will be nerve racking. Same with backing up in a busy truck stop.
    Jeck Thanks this.
  3. Kyle G.
    Kyle G. Road Train Member
    3,842
    20,160
    Jan 23, 2016
    Eastern Iowa
    My first night out with a trainer, I had to take 94 through Milwaukee and Chicago during the pm rush with a heavy load of paper rolls. By the time we got parked in Gary that night, my trainer almost needed a crowbar to pry my hands off the wheel. I was such a wreck that night that I could barely walk.
    But I quickly learned, as you will, that it's not half as hard as I thought it would be.
    1278PA and Jeck Thank this.
  4. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,293
    Sep 12, 2017
    Plymouth MI
    I used to be a surgical nurse... Trucking still makes me sweat, to many unknowns. Unless Dr Oooops was in the room. ;-)
    Jeck Thanks this.
  5. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,791
    Jan 17, 2017
    You should be nervous for the first couple weeks. That should fade into simply being aware of your surroundings.
    If, after a month, you are experiencing strong anxiety when performing basic maneuvering, then trucking may not be for you.
    Even after years of driving, there are going to be scary situations. There is one VERY narrow bridge that I cross now and then that make me pucker up at both ends when there's another truck on the bridge passing me going the other way.
    Every time I make a delivery to Norfolk, NE from the East, I cross that bridge after leaving the interstates and moving onto secondary roads.
    Jeck and Justrucking2 Thank this.
  6. Justrucking2
    3,211
    4,293
    Sep 12, 2017
    Plymouth MI
    Many folks out here that should not be driving a truck, they scare me more than you can imagine. The four wheelers are the least of my concern. The ELDs will just, and are, exasperating the situation.
  7. Moosetek13
    Moosetek13 Road Train Member
    14,662
    18,413
    Nov 1, 2010
    Burnsville, MN
    After nearly 7 years I still get nervous.
    And I would have it no other way.
    The moment you stop being afraid is the moment you start making mistakes.
    And from the reports I have seen, it is those drivers with 4-5 years experience, or more, that cause many accidents.
    They get too confident and overlook the smaller details.
    I am more confident in my abilities at this point, but I still take my time when backing or turning.
    I can hit the mark with fewer corrections, and get into docks that would have left me speechless a few years ago.
    But I still have that sense of... what am I missing.
    And I think it is what keeps me safe.
    Don't worry about backing in to a spot at a busy truck stop.
    They will wait as you back, and back correctly.
    Get out and look as many times as you need, and make them wait. Maybe they will learn something.
    Your career is dependent on how careful you are - never forget that.
    When you try to rush things, bad things happen.
    Suspect Zero, 1278PA and Farmerbob1 Thank this.
  8. Farmerbob1
    3,685
    5,791
    Jan 17, 2017
    Are you really nervous, or just careful? There is a big difference. You can be confident and careful, but It's not possible to be confident and nervous.
  9. Moosetek13
    14,662
    18,413
    Nov 1, 2010
    Burnsville, MN
    I guess some people just have to bring in electronic logs into every thread.
    Plan your time correctly and they don't matter!
    From my point of view it is those drivers that try to stretch their time so much that they can not run legally.
    They want to push things so hard to make that extra buck that they can not get a handle on simply being a safe driver.
    They tailgate other vehicles trying to get more miles.
    And all the while they are texting while driving.
    Scum of the trucking industry, and I see them all too often.
    nax Thanks this.
  10. Jeck
    Jeck Light Load Member
    167
    105
    Feb 22, 2017
    The metal gated bridge? Where you lucky enough to go on it when they had half closed with tarps? It sucked the cones was so close you either hit the cones or the tarps or the side of the bridge
    Farmerbob1 Thanks this.
  11. Moosetek13
    14,662
    18,413
    Nov 1, 2010
    Burnsville, MN
    I am still nervous to some degree.
    Less now than when I started, but it is still there.
    And while I can be confident of a situation, I can still be nervous of the outcome. There can always be that one little mistake that takes it all down.
    Being more careful is the first step.
    But beyond that is being/staying nervous enough to double and triple check yourself.
    Farmerbob1 and Jeck Thank this.
