Recently diagnosed with diabetes and mild foot neuropathy
Discussion in 'Questions From New Drivers' started by MaybeAFutureTrucker, Jul 10, 2025.
  1. MaybeAFutureTrucker
    MaybeAFutureTrucker Bobtail Member
    49
    102
    Apr 7, 2025
    Is trucking even a realistic job at this point? I understand there is a DOT physical that any trucker would have to pass? I'm sure the question of neuropathy (numbness) would come up.
    nextgentrucker and silverspur Thank this.
  3. silverspur
    silverspur Road Train Member
    1,677
    7,486
    Sep 26, 2012
    Age, height, weight, HBa1c #?
  4. MaybeAFutureTrucker
    49
    102
    Apr 7, 2025
    Age, 46. Height, 5,11". Weight, 275. A1C 8.7
    silverspur Thanks this.
  5. Frank Speak
    Frank Speak Road Train Member
    4,521
    13,825
    May 3, 2016
    Type II is reversible. You'll always be a diabetic, but you can get your A1C to at least pre diabetic range, possibly high normal range. Get your weight to where it should be and your A1C will drop like a rock, along with your BP and a host of other issues that you likely have. Frankly, I don't think a career in trucking is in your best interest. If you can't maintain a proper diet and exercise routine (aka healthy lifestyle) now, it'll likely only get worse in a truck. I'm not trying to be mean. We all have our vices. I'm just being honest with you.
    Jamie01, upnorthwpg, TripleSix and 6 others Thank this.
  6. MaybeAFutureTrucker
    49
    102
    Apr 7, 2025
    I can maintain a proper diet now because of the diabetes. I'm down almost 25 pounds in two months. I imagine this will only continue. Thank you for the reply.
  7. Espressolane
    17,609
    108,000
    You could become a truck driver. There will be a lot of hoops and red tape to get a medical waiver.
    You’re going to need quite a bit of help with documentation from your current doctor. It is going to take a while. You need to have this documentation done even before you start any CDL school. The school or company is going to require it in order to apply for the CLP.
  8. Lonesome
    Lonesome Mr. Sarcasm
    11,216
    23,058
    Dec 15, 2007
    Northern Indiana
    Good luck with your adventure.
  9. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,422
    2,429
    Jan 7, 2023
    I'm 35 years out of knowing the regulations of today; back in my time, using insulin was automatic disqualifier, unlike today. The key here is that you are RECENTLY diagnosed. This means that medications will have to be tried and tested BEFORE you will know if you can continue driving. So, at a minimum, you probably need to stay off the road for the next 6 months. And after that, you will only get like 3-monthMedical cards, so you'd better stay close to home.
    If you were only THINKING about driving, I'd suggest that over the next 6-12 months, depending on how you deal with the meds, you may need to re-consider the idea. But, no, now is NOT the time to try getting your CDL or to start driving.
    Right now, I'd concentrate on losing about100 lbs.
    The neuropathy alone isn't likely a big issue; after 400 miles of bad road, a LOT of things will be numb.
  10. silverspur
    1,677
    7,486
    Sep 26, 2012
    On the Forums section of this site, scroll down to Miscellaneous Trucking Topics then click Driver Health.
    There are some good threads with diabetes related info on them.
  11. silverspur
    1,677
    7,486
    Sep 26, 2012
