Recognizing loose lugnuts
Discussion in 'Intermodal Trucking Forum' started by OrangeCat, May 30, 2025.
  1. OrangeCat
    OrangeCat Bobtail Member
    6
    Jul 14, 2023
    I was preparing to move an intermodal yesterday and a more experienced driver was assisting me with another issue, when she pointed out that the lug nuts were close to the end of the bolts. I rejected the trailer but I want to make sure I made the right call. They didn't show the signs of looseness that I was taught to look out for in CDL school, but I did think they looked concerning. Is this normal?
  3. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    Compare it to all the others on all axle ends. All those old chassis are dangerous junk trash. You look hard enough and you'll see all kinds of things you won't like.
  4. 201
    201 Road Train Member
    12,754
    26,239
    Apr 16, 2014
    high plains colorado
    Still using wagon wheels, eh? At least it's a tubeless. I hauled a lot of RR wagons and theoretically, that lug, not the end in contact with the rim, the other end, it should not have a gap by the spoke, however, a tough call, as I've hauled many just like that with no problems, until the next flat, that's is. The rim hasn't slid, so it's not loose, and if you are ambitious, you may get half a turn, but I never really had an intermodal long enough to worry. I think you are okay.
    Bean Jr., MACK E-6 and wis bang Thank this.
  5. Judge
    91,707
    Could you move the wedge?
    Does the rail not have a service bay? Or were you not at rail?
    CSX/CN/UP in Memphis had a way to fix lights/tires is why i ask.
    MACK E-6 and Tb0n3 Thank this.
  6. Big Road Skateboard
    7,073
    40,068
    May 2, 2021
    Don't look loose. The thread that sticks past the end of a nut serves zero function in reality. Not all wedges, nuts, and hub studs are the exact same either, so judging off another set isn't definite either.
    Better safe than sorry, but I'd say those are fine.
    Next time hit it with a hammer and see if it moves.
    201 Thanks this.
  7. FLHT
    FLHT Road Train Member
    1,428
    2,541
    Aug 2, 2014
    Look for rust around lugs.
    201 Thanks this.
  8. Tb0n3
    Tb0n3 Road Train Member
    4,736
    9,646
    Oct 5, 2012
    Earth
    That's what I was going to say. Hit over the hammer and if the wedge doesn't come loose that's just how they are. It'll ride. Looks like junk though.
    lol you can try looking at the picture.
    tscottme Thanks this.
  9. 201
    12,754
    26,239
    Apr 16, 2014
    That's easier on a Budd wheel, those "rust tracks", but on a Dayton style, it's not as easy.
    Bean Jr., Sons Hero and MACK E-6 Thank this.
  10. SmallPackage
    5,775
    18,534
    Dec 20, 2019
    Marion Texas
    That is perfectly fine. 2 or more rounds of thread out of nut and 1/4 to 3/8 gap on cleat is normal and acceptable. They only torque around 185 ft lbs max. on 5/8 stud. 245 on a 3/4 stud.
