Reefer Intermittent Total Electric Power Loss
Discussion in 'Refrigerated Trucking Forum' started by GearJammer90, Oct 15, 2025.
  1. GearJammer90
    GearJammer90 Bobtail Member
    Hoping someone that has experience with this unit can help.
    Carrier x2 2100A in Start/Stop initially starts just fine, reaches set temp, and shuts off as programmed. For the next hour or so it runs Start/Stop fine. But after about an hour on another restart to begin cooling again, tries to start the engine and has TOTAL power loss. Complete blank out on control panel and electric power gone before it can even log an alarm. A moment later since the physical on switch is in the on position it begins the control panel start up as if I just flipped the on switch. Engine tries to start and unit completely loses power again, repeats until the battery is completely drained. The trailer gets benched or used as a dry van for the rest of the day since it won’t work.
    Service gets called for an after hours repair but works fine for them in the allotted time they inspect. ‘We don’t see any problems.’ I have it on video and have witnesses but it won’t do it for them. So I’m tearing my hair out.
    Has anyone had experience with their reefer behaving like this and where should I start looking since I guess I gotta figure this out.
    Thanks and God Bless
  3. reeferwrencher
    reeferwrencher Medium Load Member
    600
    1,555
    Aug 4, 2018
    Might sound simple but are the battery connections tight?
    Also is the battery cable at the starter motor tight?
    GearJammer90 Thanks this.
  4. MRMTRANS
    MRMTRANS Medium Load Member
    393
    428
    Apr 28, 2015
    I had exact same problem with a 2500 x2. Electronics to the microprocessor would cut out, particularly in the rain. Was a wire in a harness that was located along the unit frame between the micro and front of trailer. If I remember right, it was secured to the frame by tie straps, which broke and allowed the harness to vibrate and rub through the insulation. Carrier uses a tape, and not lume, to protect the wires. I used to jiggle the harness untill the micro would light up until I cut and re-spliced the one wire that had exposed wire.
