Refrigerated Loads
Discussion in 'Refrigerated Trucking Forum' started by dirttrackking55, Mar 15, 2013.
  1. dirttrackking55
    dirttrackking55 Bobtail Member
    41
    6
    Dec 17, 2011
    Georgia
    Hey, what I was wondering I havent hauled refer before but when you get a load does the shipping paper tell you what to set the temp at when hauling or do you just know after hauling it after a while?
    catdog45 Thanks this.
  3. Balakov100
    Balakov100 Road Train Member
    3,937
    2,635
    May 10, 2012
    Temple, TX
    Most of the Time it will be on the BOL.
  4. Allow Me.
    10,643
    12,114
    May 28, 2009
    Rancho Mirage, Ca.
    Correct.......plus dispatch/broker will tell you.
  5. #EZ$
    #EZ$ Bobtail Member
    4
    Mar 15, 2013
    the shipper n paperwork should both have the temp.but b 4 u leave facility always....call your dispatcher to verify temp. Never leave without knowing the temp or u will b buying the load
  6. dirttrackking55
    41
    6
    Dec 17, 2011
    Georgia
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Don't forget what should be run on cycle or continuous ... perhaps also depending on the outside temperature ...
    catdog45 and CondoCruiser Thank this.
  8. NavigatorWife
    NavigatorWife Road Train Member
    2,937
    2,080
    Apr 30, 2012
    Cental West, AL
    And of course you have the ying yang between what the BOL says, the dispatched load says, and then even the warehouse itself. Husband spends many miles sometimes with the ying yang because he will go by what the BOL says because sometimes the info on load assignment is either entered wrong or someone gave them the wrong info when placing the order.
    If it is a different temp, call your customer service dept as soon as you can and let them sort it out.
  9. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    Back when I had several reefers, I had a man apply for a job as a driver. Asked him if he knew how haul produce. He said sure. Load the truck, set the thermostat on freeze, deliver the load, let it thaw out on the receivers dock. I did not hire him.
    catdog45 and Pmracing Thank this.
  10. Sly Fox
    Sly Fox Road Train Member
    1,016
    695
    Oct 29, 2009
    BOL is king. If it's not what the broker/company told you, verify it with the shipper. If it's wrong, have them correct the BOL before leaving.
    Most meat and produce loads run on continuous. Frozen loads are -10 usually and run cycle. Protect from freeze are generally just +40 or higher. Liquid resins, etc are usually >70 and can be cycled. Ice cream is always the coldest you can get on continuous, -20 usually.
    Meat runs +24 to +28, while produce usually runs at +33 to +35 most of the time. Bananas are always right around +58 to +60 continuous.
  11. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I think sly fox may have momentarily became dyslexic with his "cycle" and "continuous" use but we know what he meant. I never had a 28 degree meat load that required continuous or a sub-zero load that didn't require continuous.
    But, I'll agree, BOL trumps all else and if there is a discrepancy, make the necessary calls to get a ruling before leaving the shipper
    alds and catdog45 Thank this.
