regroovable tires
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Sep 6, 2017.
  1. mitmaks
    mitmaks Road Train Member
    2,544
    2,065
    May 16, 2014
    What does it mean? They just cut tread onto tire?
  3. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,822
    Dec 7, 2015
    OK
    Yes you can add about 5/32nds more depth
    Generally only cut the big straight grooves
  4. benjamin260_6
    benjamin260_6 Medium Load Member
    430
    480
    Aug 8, 2012
    Ontario, Canada
    When a tire wears out there's usually a deeper tread left on the outside edges of the tire. Most guys set their re-groove to that depth and cut the center treads. The tool is kind of like a soldering gun but instead of a wire that gets hot, there's a V shaped blade. They work great and you can usually get a few extra month out of your tires
  5. bavarian
    bavarian Heavy Load Member
    727
    781
    Feb 13, 2014
    Winnipeg
    That's right. But you will loose the value of the casing. It's garbage and not reusable after regrooving.
  6. dibstr
    dibstr Road Train Member
    1,308
    931
    Sep 10, 2010
    Usually correct. That's because after regrooving it's required that
    cord material below the grooves has to have a protective covering of tread material at least 3/32nd-in. thick and there is not much way to know that without a lot of expensive equipment, so the core is essentially scrap. FMCSR 569.7
    skro47 Thanks this.
  7. Fatboy42
    Fatboy42 Light Load Member
    281
    389
    Feb 9, 2011
    Indiana
    On a dump truck I used to haul loads for a demo company I would re grove recaps when they wer almost slick. Usually ruined th sidewall before the tred was gone. I figured if the cap had not come off before all the tread was gone it was good to re grove. I worked well.
    BoxCarKidd Thanks this.
  8. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    I run junk china tires so the casing are crap anyways most can be grooved 1/4 inch
  9. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    What type. Model regroover to buy.
  10. giannid
    giannid Light Load Member
    100
    13
    Dec 6, 2015
    so can you regroove rethread or just virgin tires?
  11. xsetra
    5,094
    6,941
    Aug 21, 2011
    I've been reading today. Looks like all tires. Just don't go too deep. Need to leave the chords covered with rubber.
    I seen one guy use an all to see how deep the rubber was before he started peeling rubber.
    Some say even after you regroover, the tire can be recapped.
